Old 11-17-2021, 04:20 PM   #1
Apex Wheels
Apex Wheels's Avatar
Drives: Camaro Z28
APEX Wheels | Introducing Our Forged Sprint™ Line - Our Lightest Wheels
Our forged Sprint™ line was built to be extremely light while still offering a meaningful strength increase over our flow formed wheels.
➡︎ 10K ton forged 6061-T6 aluminum
➡︎ Stronger Sprint™ spec inner lip
➡︎ Side-milled spokes for reduced weight
➡︎ Massive brake clearance
➡︎ Independently tested and certified
Finishes
10K Tons Of Pressure
Our new forgings weigh as much as 120 pounds before machining. To form such a thick blank we require special equipment capable of 10,000 metric tons of pressure. This extreme pressure increases the strength of the aluminum by eliminating porosity and improving the grain structure.
True Motorsport Blanks
Many companies use 3rd-party blanks intended for non-motorsport wheels which can severely limit sizes, concavity, spoke design, and critical brake clearance. We designed our very own blank profiles from scratch which gives us total control over the final product, resulting in exceptionally deep spokes and stronger designs.
Learn more our true motorsport blanks.
Side-milled Spokes
One of the most significant upgrades to our Sprint wheels is the addition of wider and deeper side-milled spokes. Any excess material that doesn’t add strength is carved out using a precision CNC ball cutter. Side-milling is often deemed cost-prohibitive by others, but for true performance without compromise we believe it's essential.
➡︎ 40-50% Wider
➡︎ 50-100% Deeper
Learn more about our wider and deeper side-milling.
A Stronger Lightweight Wheel
Our forged Sprint™ wheels are lightweight without the strength compromises found on typical lightweight wheels. First, we carved out as much material as possible, then we purposefully added one pound back to reinforce critical areas, creating a stronger inner lip and a higher load rating.¹ What’s the point of a lightweight wheel if it’s fragile?
Weight Optimized
We conducted extensive Finite Element Analysis (FEA) to reinforce high-stress areas and to remove material where it didn’t improve strength. The result is a wheel that is exceptionally light without the strength compromises found on typical lightweight wheels.
Independently Tested
We don't rely solely on computer simulations or unverifiable in-house testing. We believe independent testing is critical to protect consumers in this unregulated industry. We chose STL, an independent lab in Ohio, to test our Sprint™ wheels far above JWL standards, including increases in testing duration, impact drop height, and total load.
Learn more about our rigorous independent testing.
Tough Inner Lip
Introducing the Sprint™ spec inner lip, with a unique channel profile that makes it even stronger than our previous designs. So even though our Sprint™ wheels are pounds lighter than comparable flow formed wheels, the inner lip is stronger.
➡︎ 32% more reinforcement than our flow formed wheels.
Learn more about our Sprint™ spec inner lip.
Big Brake Clearance
From day one, APEX has been on a mission to build wheels that clear big brakes. Our new forged wheels are the product of everything we’ve developed over the past 10+ years, including an innovative high-clearance barrel design and vehicle-specific spoke profiles.
Deeper Concavity
Our new forgings were redesigned to create extra deep, concave spoke profiles. Their new shape allows us to make any profile, from flat to deep and everything in between. Each one is optimized for a specific application using 3D laser scans of factory and aftermarket brake kits.
Paintless Knurled Beads
Whether it's a day at the track or months of street driving, repeated hard braking and acceleration can make a tire slip along the bead seat and go out of balance, causing vibration. Knurled beads help, but are less effective when painted over. Our forged line features unpainted knurled beads that stay sharp and maximize grip.
Learn more about why our forged wheels have unpainted knurled beads.
Built for impact sockets
Track wheels need track tools. Don’t settle for wheels that require undersized tuner lugs or thin walled sockets. All APEX wheels accommodate over-sized race lugs and impact sockets to make swapping wheels lightning fast.
Laser-Engraved Specs
As track enthusiasts ourselves, we know how frustrating it is to try to locate and decipher wheel specs that have been hastily hammered into the rim or become unreadable over time. With our new Sprint™ wheels, we chose to invest a little extra and laser-engrave the specs on the barrel, in plain sight, making them easy to find and read. (You’re welcome.)
APEX Forged Sprint Line Wheel Gallery
VS-5RS Gallery
EC-7RS Gallery
Learn More
VS5-RS / EC-7RS
Cory - Fitment Specialist | Phone: 925.245.0773 | expert@apexwheels.com
Website | Instagram | Facebook | Blog
Apex Wheels is offline   Reply With Quote
Old 11-17-2021, 07:04 PM   #2
Apex Wheels
Drives: Camaro Z28
18" EC-7RS Detailed Shots
18" VS-5RS Detailed Shots
Old 11-17-2021, 07:05 PM   #3
Apex Wheels
Drives: Camaro Z28
Crazy to think, but this is our first ever, in-depth video about any of our wheels.
Our engineering team put 2 years of hard work into our new Sprint Line and the forging dies that made them possible, so we were compelled to create a technical video that dives into the details. This video has a lot of great content our product descriptions don’t include. After watching, we’re confident you’ll truly appreciate why these features are so valuable.
If you're craving more content, this should quench your thirst.
Old 11-24-2021, 02:42 PM   #4
Apex Wheels
Drives: Camaro Z28
Paging Camaro owners in the Bay area! If you're interested in free professional photos of your car on brand new APEX wheels, we are looking for volunteers for test fitting and photoshoots! Volunteers will get copies of the photos, a discount on a set of APEX wheels, and APEX goodies/swag. If you're interested in volunteering, please email us at info@apexraceparts.com with your contact information, location, and a photo of your car. All are welcome. Show us what you've got! If you'd like to take an inside look at what these photoshoots involve, our good friend Blake made a video detailing the process of an 18" test fitment on his F82 M4 recently.
Old 12-03-2021, 07:02 PM   #5
Apex Wheels
Drives: Camaro Z28
As we kick off the last four weeks of this Group Buy, we wanted to touch base to let you know that our first wave of production is right on schedule. This means we are currently on track to fulfill your orders in the timeframe outlined on the fitment table under the overview tab. Things could always change, but everything is looking better than expected currently.
As a reminder, if you have only expressed interest and have not pledged, you're not officially a part of the deal to receive wheels. With nearly 400 members interested, some popular fitments and finishes will sell out in the first production run. We’ve already placed a restock order and it should be here pretty quickly, but we have not decided if we will cancel backorders or if we will allow late participants to get the discount and receive wheels from the second shipment. Be sure to come back and submit your pledge to lock in your order now to avoid the rush that always happens in the final week.
Technical Note
As a group of track enthusiasts and racers, we understand how frustrating it can be to bend a wheel in pursuit of a PB or podium finish. Whether you find yourself 4 wheels off track on a safari excursion or creating your own driving line jumping treacherous berms, wheels are put through a tremendous amount of stress and abuse in the process – sometimes simply being forged isn’t enough to avoid bends.
To mitigate this, our engineers made a concerted effort to reinforce the inner lip of these motorsport wheels and created our stronger, Sprint™ Spec inner lip design. If you haven’t already, we recommend you read our technical writeup on our Sprint™ Spec inner lip.
Blog: MEET THE STRONGER, APEX SPRINT™ SPEC INNER LIP
Old 12-08-2021, 07:20 PM   #6
Apex Wheels
Drives: Camaro Z28
When Function Meets Form
As wheel specialists we understand that, when it comes to reducing weight and increasing stiffness in wheel spokes, there is a big difference between functional and aesthetic side milling. Instead of milling a few negligible millimeters of depth just to look cool, our engineers optimized our new motorsport blanks to create narrower yet significantly deeper spokes, with deeper side milling that is nearly 50mm wide on some wheels. The result is a stiffer “I” beam-spoke shape that also showcases a stunning aesthetic. If you haven't already, we recommend you read our technical write-up on our deeper and wider side-milling.
Blog: HOW DEEPER AND WIDER SIDE-MILLING MAKES WHEELS LIGHTER
Old 12-13-2021, 06:55 PM   #7
Apex Wheels
Drives: Camaro Z28
Wow, we’re closing in on 200 pledged and 400+ interested. Thank you to everyone who signed up and made this deal a success. For those who haven’t submitted their official pledge yet, please be sure to do so soon, or you’ll be at risk of your preferred design or color running out. Here are some lovely photos for viewing pleasure:
Technical Note
As racers and automotive enthusiasts, we understand that safety is a top priority when modifying your car. In the United States, there are no testing requirements when it comes to producing wheels, leaving the industry entirely unregulated. Unfortunately, this opens the door to shortcuts and cheating by unscrupulous manufacturers.
Here at APEX, we conduct extensive and expensive safety testing to ensure our wheels are safe, and results are independently validated by a 3rd party. To find out more about our testing process, and why we chose Standard Testing Labs, based in Ohio, be sure to read our technical write-up linked below.
Blog: TESTING TO A HIGHER STANDARD
Old 12-17-2021, 07:02 PM   #8
Apex Wheels
Drives: Camaro Z28
Production Update
Batch 1: The first batch of wheels is arriving at our warehouse in the first week of January. We are on track to fulfill these wheels in January as planned. We will continue to notify everyone once orders begin to ship out.
Batch 2: Production is being buttoned up, and we are on track to ship orders out in March without delay. We do not expect any delays at this time and will update everyone once production is completed.
Reorder Production: Due to the success of this deal, we are already producing additional wheels to arrive a few weeks after the 2nd batch.
Video Q&A With Our Founder
Our Marketing Director sat down with our CEO to discuss the in’s and out’s of our new Motorsport Blanks. Check out our latest episode of APEX Tech Talk to learn about the difference between our motorsport blanks and typical “street” blanks.
Old 12-22-2021, 06:32 PM   #9
Apex Wheels
Drives: Camaro Z28
Batch 1 & 2 arrival clarification:
Some of you were confused by our last update regarding the January and March arrival of wheels, and we wanted to provide some clarification. We produced a significant number of wheels, so all sizes won’t be finished at the same time. The first batch is set to ship out to customers in January, and the second batch will ship out in March. We recommend viewing the “Available Fitments” table on the deal description tab for an ETA of your desired fitment.
The vast majority of participants will receive wheels in accordance with the ETAs listed on the fitment tables. However, with such a high volume of participants, it’s possible that popular sizes from the first January batch run out. Don't worry, we’re already making more and they should be ready to ship out at the end of March. Only once the deal comes to a close will we know accurate ETA dates per order as many people have backup designs and finishes selected, so a calculation can’t be made at this time. In a future update we’ll provide more detail on the options you’ll have once the deal closes, for processing your order.
Old 12-29-2021, 06:54 PM   #10
Apex Wheels
Drives: Camaro Z28
Shipping is on Schedule:
The first batch of wheels are almost ready to ship. Orders should be able to start shipping the first week of January, after we’ve reviewed and processed each order.
This deal officially ends in three days, and we will not be able to accept any new pledges once the deal closes, so take advantage of one of the shortest fulfillment times we’ve ever had on a Group Buy.
EC-7RS on a Camaro:
We were unable to schedule an EC-7RS photoshoot on a ZL1 1LE before this deal ended, so we put together a nice rendering. This render simulates the 18x11” and 18x12” setup in the Anthracite finish.
VS-5RS on a Camaro:
We did find a VS-5RS photoshoot we did a few weeks ago that we realized wasn’t shared with the group. we’re excited to share our friend Alessandro's 6th Gen Camaro 1LE ZL1. These VS-5RS wheels are 18x11” ET7 front, and 18x12” E41 rear, paired with 315/30-18 and 335/30-18 BFGoodrich Rivals tires respectively. The finishes shown are Anthracite and Satin black.
Old 01-04-2022, 07:04 PM   #11
Apex Wheels
Drives: Camaro Z28
Thank you to everyone who participated in the Group Buy! It is now closed and we will be in touch will all who ordered. Have a good one!
Old 02-19-2022, 01:46 PM   #12
Crash76
Team 913
Drives: '14 ZL1, '15 Jeep GC, ‘22 Ram 2500
20” 5rs ?
Crash76 is offline   Reply With Quote
Old 03-17-2022, 10:15 PM   #13
TacSac
Drives: 2013 ZL-1
can you get 18s for a 5th gen ?
TacSac is offline   Reply With Quote
Old 04-14-2022, 07:23 PM   #14
Apex Wheels
Drives: Camaro Z28
Originally Posted by Crash76 View Post
20” 5rs ?
Yep those are coming this August! 20x10.5" ET15 and 20x11.5" ET42 will be offered
Hi, yes you can. All our 18" Camaro wheels fit the 5th Gen cars.
