02-20-2018, 05:20 PM | #1 |
Drives: rumble bee,2SS 6sp Join Date: May 2009
Gear wear pattern. What do i need to change
What needs shimmed
blk 2ss 6spd with sunroof.
intake,tsp cam,full exhaust,pcmforless tune,trailing arms,toe rods. hopeing for 11.9 because my g/f said she will take the cam and the suspension back if not. |
02-21-2018, 05:18 AM | #2 |
Drives: 12 camaro ss, 72 chevelle, 91camaro Join Date: Dec 2013
what's backlash at? looks like it needs to be deeper in the ring gear. and maybe a little bit added to the pinion shim. I like to take a beating and hone out the center so it slides on and off by hand just to set them up and put a new bearing on when it's all said and done. so you're not pressing it on and off, potentially destroying them
02-21-2018, 07:06 AM | #3 |
Backlash was at .0035
02-21-2018, 08:48 AM | #4 |
I'd try adding a little bit to the pinion and see what you've got then. that should move the pattern towards the heel a little and get it a little deeper in the ring gear
these rears take very minimal backlash so that is good.
02-21-2018, 09:18 AM | #5 |
Drives: 2010 SS 2SS M6 Join Date: Aug 2016
What gears OP? If AAM please read up on 2 step vs 5 step cut gear sets...http://www.demandaam.com/technical-s...ng-pinion-sets
when I did mine since it is a 2 step cut the pattern WILL look a bit different than what most people expect...and setting the pinion depth can be a B(the above suggestion regarding making the bearings internal id larger works but only if replacing the bearings-most don't-I did) on a non GM WILL require a diff pinion shim...I got lucky(not really-research pays off) and was able to just take the shim from my 3.45 and put it on the AAM pinion...even after replacin all the bearings the pattern and backlash were perfect-.002 on the backlash, tight to allow breakin..used Mobile LS gear oil, change at 500 mi..over 2 to 3k mileage so far...whisper quiet. mileage includes about 50 runs down the 1/4 and lets just say some hwy over 100(safely!HAHAHA). good luck OP looks like you are on the right track..make sure to get the bearing caps tq'd properly and while you are in there seriously consider replacin the axle seals..easy and cheap. l8tr
