Old 08-04-2017, 11:18 PM   #1
PhatStackSS
PhaSSt
PhatStackSS's Avatar
Drives: 2011 Camaro SS
Arrow Cam/Lifter Help
My father is a mechanic and will install everything for me BUT I have a question about the lifters.
I plan on getting new lifters but I do not know which lifters I can use or I need. I have a Lethal Racing Night Fury Cam.
Any help, helps me out alot. I also am buying a trunnion upgrade, C5R timing chain, and 3 bolt camshaft kit. Thank you for all the help!
PhatStackSS is offline   Reply With Quote
Old 08-04-2017, 11:45 PM   #2
go_go_gadget88
go_go_gadget88's Avatar
Drives: 2010 Camaro 2SS/RS ABM 6M
Any particular reason you are changing the lifters in it? AFM/DOD delete? Crazy cam specs?
Just curious what is wrong with the ones in it
go_go_gadget88 is offline   Reply With Quote
Old 08-04-2017, 11:50 PM   #3
0331Marine
0331Marine's Avatar
Drives: 2012 SS/RS MN6
I put a new set of factory lifters in when I did my heads and cam.
0331Marine is offline   Reply With Quote
Old 08-05-2017, 02:13 AM   #4
PhatStackSS
PhaSSt
Many people have told me I should upgrade the lifters while I'm changing the cam out. I also seen many people say on forums to upgrade lifters if I'm not running stock cam. I have 61k miles on the engine, also I am putting kooks headers in while I'm at it.
2011 Camaro SS | Cat-Back Borla ATAK | Roto-Fab CAI | Night Fury Cam | Kooks 1 7/8 x 3" Headers
Old 08-05-2017, 06:16 AM   #5
07-SRT
07-SRT's Avatar
Drives: 2015 Camaro SS
If you're going to do the lifters your going to have to pull the heads at that point you might as well get them ported.also don't forget to replace the lifter trays when I did my ported heads at 15K the lifter trays were a little loose holding the lifters compared to the new ones...I went back with the stock ls7/ls3 lifters
2015 Camaro 2SS
Cam/Heads/FBO 498/447 SAE
07-SRT is offline   Reply With Quote
Old 08-05-2017, 09:48 AM   #6
jc615
jc615's Avatar
Drives: Camaro and Sierra
As mentioned above, stock lifters will be fine to replace with if you decide to replace them. At 61k I would just for peace of mind.
jc615 is offline   Reply With Quote
Old 08-05-2017, 04:58 PM   #7
PhatStackSS
PhaSSt
I'm just wondering what the difference in the lifters are? I've been looking at COMP Cam Lifters since alot of people recommended them to me but is there different sizes? What lifters can I use with my Night Fury cam? Just need recommendations, thank you
Old 08-06-2017, 05:54 AM   #8
Avenging Orange
Avenging Orange's Avatar
I think you are going to keep getting the same advice....if you replace...go stock.
https://youtu.be/9JD9it6SmB8
https://youtu.be/xmelTlEzI34
Old 08-06-2017, 06:28 AM   #9
07-SRT
07-SRT's Avatar
IMO stick with the stock LS7/LS3 lifter as they have quite a bit of plunger travel that will handle a wider range of preload. The only other lifter I personally would use is Johnson lifters that are used in copo camaro, however you need to be exact on recommended preload.Either
way you will still need to measure for p-rod length.
2015 Camaro 2SS
Old 08-06-2017, 08:53 AM   #10
christianchevell
old school chevy rodder
christianchevell's Avatar
And replacing the lifters is a must as they have established wear patterns in the stock stick if they have more than a few miles on them and have most likely some defects from the stock bump stick that may want to transfer into problems for the new one let alone the wear they take. I use BTW driven racing oil BR30 to break in even a cam not just a whole engine..... And dad should know you have 1.7 ratio rockers so setting the preload into the golden .040-.060 area for stock ls3/7 for low noise is about 3/4 turn being that the .047 thread pitch of the bolts threads for the rockers move the rocker .047 x 1.7 for actual movement with whole turn.......
Old 08-07-2017, 10:09 AM   #11
go_go_gadget88
I thought that wear patterns weren't as relevant with the roller lifters like they were back in the flat tappet days?
I am looking at doing a cam swap, and it seems like a lot of people don't even pull the heads for the change. Many I have read about just change out the pushrods and springs, but leave the lifters. I didn't plan on changing mine. But I also only have like 20k on them
Old 08-07-2017, 05:35 PM   #12
LSX Camaro
Master ASE, GM, LSX Tech.
LSX Camaro's Avatar
Drives: 2010 Camaro SS
Johnson 2110 Lifters
2010 2SSRS A6, Custom Pat G. Cam, WCCH Cylinder Heads, Kooks Headers/Exhaust, BTR Valvetrain, Fluidampr 25% UDP, All Engine ARP bolts, Flex-a-lite radiator/Trans cooler, Yank converter, PFADT Suspension, ADM Race Intake/Scoop, Torq tow hook, CFD auto shifter, Dynojet AFR gauge, Aeroforce scan gauge, Brake Performance rotors/pads
Prothane bushings, ZL1 wheels, spoiler, Z/28 wickerbill, 1LE Aero/Suspension Package, Anderson Composites COPO Carbon Fiber Hood, LED lighting, Elite Catch Can, Improved Racing oil pan baffle, crank scraper, windage tray
480 RWHP 452 RWTQ + Nitrous Express 150 Shot
LSX Camaro is offline   Reply With Quote
Old 08-09-2017, 09:46 AM   #13
gmcvt
gmcvt's Avatar
Drives: 2019 Camaro 1SS A10
Installed a cam around 70K and chose to replace my entire valve train including lifters and lifter retainers. Installed new GM pieces and all has been well.
"Jesus said to them: I am the way, the truth and the life and no one comes to the Father except through me" John 14:6
2020 Mustang GT M6
2019 Camaro 1SS A10 E85/Pray tuned & ported IM/TB.**SOLD**
2018 Mustang GT A10 Kooks Lt's, E85 & Lund tune*SOLD*
2010 Camaro 2SS/RS M6 Silver- CAI, Bo-body, VRSP-2 cam, Kooks 1 7/8 Lt's w/cats, Magnaflow street CB(15089), QTP ovals, Elite can, Vengeance Racing tune. *SOLD*
gmcvt is offline   Reply With Quote
Old 08-09-2017, 05:31 PM   #14
dino2012ls3
Drives: 2012 ls3
First cam lasted almost 20k before original lifter collapse. Second time around another shop swore by LS7 lifters and now 469 rwhp on mustang dyno and almost 60k miles on new set up not a problem or worry yet
dino2012ls3 is offline   Reply With Quote
camaro ss cam, camshaft, lifters
