05-25-2017, 03:34 PM | #1 |
Drives: rumble bee,2SS 6sp Join Date: May 2009
Cut out stopped working but have xpipe
My pass side cutout stopped working but it is after the xpipe. I have headers no cats xpipe and cutouts before the magnaflow mufflers. I assume that having just the one open and the pass side one just goin thru the muffler will be fine?
blk 2ss 6spd with sunroof.
intake,tsp cam,full exhaust,pcmforless tune,trailing arms,toe rods. hopeing for 11.9 because my g/f said she will take the cam and the suspension back if not. |
05-26-2017, 07:10 PM | #2 |
Drives: Savitar; The 500rwhp N/A Monster! Join Date: Aug 2016
You should be fine buddy
*SOLD*504HP/433TQ | Night Fury cammed Cold Air Inductions intake Bo White ported TB Speed Engineering 1 7/8 longtubes NPP catback QTP low profile cutouts Powerbond 25% UDP 3.73 gears JRE scoop ZL1 grille R1 Concepts drilled/slotted rotors built/tuned by Weapon X Motorsports
05-26-2017, 09:28 PM | #3 |
It may not be optimal, but that exhaust will find it's way out, so I wouldn't worry.
2010 CGM Camaro 2SS LS3 Swapped A6 - GPI LS3 SS1 .647/.638, (224/237, 112 +4, 7Ί overlap) on CamMotion 8620 core, BTR Platinum .660" Dual Spring kit w/titanium retainers, CHE bronze trunnion upgrade, stock heads milled @ .015, Melling HV 10296 oil pump, TSP 1-7/8" long tube headers (W/Catless Off-road Pipes), Corsa Xtreme 3" Catback, GPI Ported/Rod Mod Intake, Stage 2 Ported Throttle Body, Vararam OTR CAI, Mike Norris Gen 2 catch can + GM 1LE clean side separator, 160Ί thermostat - Megan Racing adjustable coilovers (lowered 1.75"), MRR M017 10/11" wheels-Tuned by Ryan @ GPI
06-04-2017, 10:32 PM | #4 |
Drives: 2011 2SS/RS Victory Red Join Date: Aug 2011
The ones on the 68 get clogged up every once and a while. We just bang on them a bit and fire a bunch of wd40 in them. They eventually free up. Exhaust has moisture in it and well, the shaft tend to rust up and hang, plus the carbon doesn't help.
Updates: BTR Stage 2 VVT Cam Kit w/Smith Brothers Trunnions, Fluidampr, RX catch can, B&M Trans pan mod, Kooks Black Headers, Borla S-tunes, Eibach Multi-Pro-R2 coilovers and Swaybars, BMR Full Bushing kit with Toe and Trailing arms, RB Rotors w/EBC Pads, GForce 1400 Axles (now on order). AVH-X5800BHS in Scosche GM5201AB. |
