05-30-2020, 12:56 PM | #1 |
Drives: 12 2SS/RS L99,11 2SS/RS LS3totaled Join Date: Jun 2019
vararam/eBay aluminum "racing" radiator install for 10/11's
i kept my vararam off my 2011 it don't work on a 2012 the radiator is different i'm thinking about just changing to a 2011 radiator.
has anyone else had this happen? Last edited by lemontwist; 06-14-2020 at 09:53 PM. |
05-30-2020, 01:24 PM | #2 |
Ive got a buddy that swapped his 2013 radiator/condenser/fan assembly out to run his.
05-30-2020, 03:14 PM | #3 |
05-30-2020, 04:10 PM | #4 |
Condenser and fans has to be swapped too.
05-30-2020, 08:32 PM | #5 |
05-30-2020, 08:34 PM | #6 |
Thats what my buddy did. Got everything off a wrecked low mileage 2010
05-31-2020, 12:41 AM | #7 |
Fallen "soldier"
SOLDER: |
05-31-2020, 09:33 AM | #8 |
05-31-2020, 10:41 AM | #9 |
It don’t come easy.
Anyone that can come out of a wreck like you were in and score a new ride in short order has A+ abilities in my book, regardless if’n da spelling ain’t so guud.
05-31-2020, 02:55 PM | #10 | |
the new twist made it home and before she cooled down we had the exhaust off and the magnaflow cat back on,vitesse T/C and found out the vararam won't go on. got up and went to work on a better clean up. 1st shot is 2 min after i got home. the second is as of now |
05-31-2020, 04:17 PM | #11 |
Give speed a chance
Wow man that car is YOU! Glad to see things are evolving. Keep up the good work and positive vibes!!!
06-01-2020, 09:12 AM | #12 |
Lol you’re not wasting anytime just gonna get right to modding. Hope you score a 10-11 radiator setup so you can get the vararam on there
2010 2SS/RS
06-12-2020, 08:08 PM | #13 |
thank you Bo White, it was 6 of 1 half dozen of the other a new CAI cost about as much as a 2011 swap. so i sorta upgraded with some feebay stuff.my friend has a a/c capture recharge machine and i do my own work so no labor costs. i figure i'll change alot of fluids this weekend- coolant,oil change,break fluid flush and diff.
they took a $170 offer for this.we will see if it's any good...... https://www.ebay.com/itm/3-Rows-Alum...72.m2749.l2649 scooped this up https://www.ebay.com/itm/AC-Condense...72.m2749.l2649 and got some fans for 80 bucks.so the vararam will be going on the 2012 |
06-12-2020, 09:24 PM | #14 | |
Let us know how that new radiator works out for you fitment wise. Good luck!
