Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Sponsors Classifieds Marketplace > Suspension / Chassis / Brakes
Old 03-18-2014, 07:27 PM   #1
Dropspeed
2013 Camaro SS1LECTSVZ28
Dropspeed's Avatar
Drives: 2013 AGM 1SS/1LE
CTS-V 6 Piston Brake kit from $1185.00 (updated)
7/09/2015
I just check prices on the front rotors and they have gone up t0 $255 / $258
Be aware my pricing in this thread is from 2013.....subject to change!
5/08/2015:
If you need dust seals for the CTS-V/ZL1 calipers or pistons/seals here are the parts numbers:
19207044 Dust Seals: Appear to be dealer only, about $25/caliper
25940445 Pistons & Seals (dust seals not included) $116.96/caliper
4/4/2013 I updated the title price from the $1050 to $1200 because the ACDelco pads ($45) are not the same material as the OEM Brembo/Ferodo 1000 pads. ($175)
PIF = Pay it forward....I will use this to mark threads for information I have located or found that I could not find easily here and may save other the time and some money.
Time to pay it forward! I finally ordered my set-up today so it was time to share.
From my research into 6 piston set-ups for my car I found by far the lowest prices on Amazon if you are willing to use Silver or Yellow (or powder coat). The qty in stock fluctuates and sometimes the items go on back order, but if you keep checking back they are usually restocked often.
You can get a 6-piston front big brake set-up for about $1050.00 to $1300.00 depending on rotors and lines you pick.
Here you go: Part numbers and prices as of 3/18/2014
Silver CTS-V Front 6 piston Caliper
ACDelco 172-2488
$246.46
ACDelco 172-2487
$250.62
Yellow CTS-V Front 6 piston Caliper
ACDelco 172-2521
$240.11
ACDelco 172-2522
$265.79
Front pads (See Notes Below)
I removed the less expensive front AC Delco Pads as the material is not the OEM Brembo/Ferodo 1000 material.
For track use please purchase the OEM pads p/n 171-1040..About $175
See page 3
Front Pin Kit
ACDelco 18K2108X
$20.98
Front 2-Piece Rotor ZL1/CTS-V
ACDelco 177-1145
$222.56
ACDelco 177-1146
$246.87
Front Dual Cast Rotor CTS-V
ACDelco 177-1105
$165.57
For the CTS-V upgrade on an SS you will need:
  • Two calipers (silver or yellow),
  • A pair of rotors: 2 Piece are better for cooling and are directional (L and R) 1 piece are cheaper, cooling is not as efficient and they "click". (search CTS-V brakes clicking) All 2012+ CTS-V use 2 piece rotors
  • Pads: Stock are listed....other High Performance options available.
  • Pin Kit
  • Caliper Bolts: ( I got mine from Rodgers Chevrolet: P/N 11570788 $3.19 each (I couldn't find the correct ones on Amazon)
  • Brake lines: (CTS-V/ZL1 front lines are a tad longer) I ordered Goodridge lines from a distributor. P/N 12227 ($185ish/4) is the ZL1 kit or you can get stock front ZL1 lines from the dealer (about $110/pair)
  • Brake Fluid: ( I used Motul 600) about $15.00 online, need 2-3 bottles.
Disclamer: Use list at your own risk...I verified fitment of the ACDelco numbers by searching them on Ebay....Once found I looked at the fitment listed for each part number to confirm.
UDATE: 4/4/2014
I ordered the OEM pads and received them today.......The pictures do not do them justice as far as how different the material is betweern the OEM pads and the AC Delco pads
I have received data in regards to the factory pads temp ranges from testing at GM and will share what I can later....
Finally, I am using the Silver CTS-V rear calipers to match the front and they ARE NOT a direct bolt on. Both the GEN1 and GEN2 calipers require modifications to use. I KNOW "but everyone says they bolt on" They are all wrong as a modification is need to both to use.
I ordered both sets-to view/confirm the differences....I will post a separate thread about the calipers, differences and mods that need to be made to use them.
-Matt
Do you really need CTS-V big brakes!
http://www.camaro5.com/forums/showthread.php?t=360552.
Dropspeed is offline   Reply With Quote
Old 03-18-2014, 07:55 PM   #2
Southern Comfort
No Tags/Habitual Violator
Southern Comfort's Avatar
Drives: 2012 SIM 2SS/RS & z71
Great info Matt !
I havent used my brakes enough yet to justify this upgrade, but have the feeling it's likely to be my first mod.
Are the caliper numbers left and right?
Southern Comfort is offline   Reply With Quote
Old 03-18-2014, 08:02 PM   #3
ssmike
BL1ZZRD
ssmike's Avatar
Drives: '16 Camaro 2SS, '20 Equinox Redline
Thanks for posting! Those are good prices! I'll be doing this next year and I'll probably get the silvers and send them to Mike the powdercoater for $180 to match the RJT of the car!
ssmike is offline   Reply With Quote
Old 03-18-2014, 08:17 PM   #4
flyinglow57
Drives: rumble bee,2SS 6sp
same part number for the first 2 piece rotor and the cast rotor just a heads up
blk 2ss 6spd with sunroof.
intake,tsp cam,full exhaust,pcmforless tune,trailing arms,toe rods. hopeing for 11.9 because my g/f said she will take the cam and the suspension back if not.
flyinglow57 is offline   Reply With Quote
Old 03-18-2014, 08:19 PM   #5
Dropspeed
Dropspeed's Avatar
Originally Posted by Southern Comfort View Post
Great info Matt !
Even are right hand side...odd are left for all GM parts (at least they are suppose to be).
2 piece rotors are directional and left/right as well because of the cooling veins...1 Piece Dual cast are not directional
Matt
Old 03-18-2014, 08:20 PM   #6
Dropspeed
Dropspeed's Avatar
Good catch....Corrected above!
Old 03-18-2014, 08:33 PM   #7
bannonm
bannonm's Avatar
Drives: 2011 2SS/RS M6 VR
Awesome post. Not ready to pull the trigger yet, but this is subscribed. Thanks
bannonm is offline   Reply With Quote
Old 03-18-2014, 09:11 PM   #8
AG1LE
AG1LE's Avatar
Drives: '14 1LE
Great information - this will let me buy a piece or two at a time
AG1LE is offline   Reply With Quote
Old 03-18-2014, 09:23 PM   #9
So Cal Camaro
So Cal Race Team
So Cal Camaro's Avatar
Drives: 2013 Camaro
This brake set up makes a huge difference in stopping power....
Damn, I just got ZL1 rotors that cost a lot more than those....oh well, next time...
So Cal Camaro is offline   Reply With Quote
Old 03-18-2014, 11:00 PM   #10
So Cal Camaro
So Cal Race Team
Drives: 2013 Camaro
Originally Posted by 130R View Post
Have you done any measurements, like 60-0 or 100-0 to compare the 6-piston Vs 4-piston calipers?
Nope, it's my opinion based on my experience...I'm not consumer reports...
Old 03-18-2014, 11:15 PM   #11
So Cal Camaro
So Cal Race Team
Drives: 2013 Camaro
Oh ok. So you have no real knowledge as to how much difference they actually make.
And for the record, I'm not Consumer Reports either, but I did compare 60-0 distances so I would have that knowledge.
Knowledge is a good thing; conjecture, not-so-much...
Experience is a better thing, armchair heckler, not so much....
Old 03-18-2014, 11:20 PM   #12
SSeric
SSeric's Avatar
Drives: '10 Camaro 2SS/RS LS3
Great post! Subscribing for future info.
Sent from my SAMSUNG-SGH-I337 using Tapatalk
2010 Camaro 2SS/RS | RotoFab CAI | ARH 1 7/8" LT Headers w/ HFC | SW Retro Exhaust | ZL1 Shifter | Ridetech Coilovers | FE4 conversion | UMI toe rods & trailing arms | Prothane Subframe & UCA bushings | Detroit Speed sways | Forgestar F14 wheels | ZR1 Blue Calipers | Tuned by ADM Performance
SSeric's Build Thread
SSeric is offline   Reply With Quote
Old 03-18-2014, 11:21 PM   #13
CHMSC
ROAD COURSE JUNKIE
CHMSC's Avatar
Drives: 2012 SS/RS LS3
Do these bolt right up or is there an adapter needed to make them work?
CHMSC is offline   Reply With Quote
Old 03-18-2014, 11:22 PM   #14
So Cal Camaro
So Cal Race Team
Drives: 2013 Camaro
They will bolt right up...you need a little longer brake line than the stock SS
