04-18-2014, 04:08 PM | #407 | |
KaBoom1701
Drives: 13' ZL1 Red M6 Join Date: Dec 2012
Awesome, Joe, is there a way you can send me a PM with everything I need to place the order on your website based on all the info above. I'd like to tear into this once when I get everything instead of saying "crap", now I need to order something else. lol Thx
Mods:
Roto-Fab Intake, WW Res. kit & Big Gulp Air Scoop, Elite Catch Can, ATI Super Damper & 18% OD Pulley, LF Idler pulley bracket, Metco CC breather, ID850 Injectors, Stainless Power Headers w/ ceramic coating, TR71X Spark Plugs, JMS Fuel Pump Booster, Bo White TB, Tuned by Ted @ Jannetty Racing, Ron Davis HX, D3 Reservoir, Pfadt 1" Springs, Moreno Camber Plates, ZL1 Addons Splitter guard washers, Tow Hook kit & rock guards, Hurst Shifter Billet Plus 6 Speed Short Shifter, ZL1 DRL lighting harness, ZL1 Recaro Seats. |
04-18-2014, 07:45 PM | #408 |
Drives: 2010 IOM Camaro Join Date: Aug 2012
I dont have a photo at this time, but I installed my SL boxes in my Glove box and ran wires out from there. This is one central area if needing to get to boxes. I dont use my glove box so perfect location while keeping dry
04-29-2014, 10:40 AM | #409 |
Drives: 2010 2LT RS Camaro 2015 Colorado Join Date: Dec 2009
I put an SL module on right side (inside) of console, hidden basically next to gauges.Right now just running a couple strip lights under dash.
04-29-2014, 11:01 AM | #410 |
Camaro CRAZY
Can dash ABL be ran on a SL module? I want to put both fog light drls on their own channel, ABL on its own, and footwells are their own. How many SL modules do I need? Lol. Do I need pig tails or what? Saw the SL modules are on sale too! Yay!
04-29-2014, 11:12 AM | #411 |
Drives: 2011 SS Convertible Join Date: Mar 2013
Depends on what you run for the ABL. The SL ports stand for "strip light". That really just means that they run at 12V, and have built-in current limiting (such as resistors or a driver, such as is on the DRL Halos). If you want to do RGB ABL, the RGB LEDs would have to have resistors on each color on each LED. Alternatively, SJM is starting to put together NightOwl ABL kits.
Footwells are easy...they are normally strip lights and can go into one port. You can run a wire from the PWM input on the SL module to the gray dome wire. This allows the floorboard lights to come on when the doors open, and they dim up/down with the dome light. SL Pigtails are only needed for the halo kit module since it is in a watertight case and the wires come out to connectors. SL modules just use screw terminals for the wires. Last edited by Joe@NightOwlLEDs; 04-29-2014 at 11:36 AM. |
04-29-2014, 11:20 AM | #412 | |
Not sure if you noticed our banner ad...do you recognize your car? |
04-29-2014, 11:32 AM | #413 | |
Contacting Craig at Scorpion Customz about the location of my master module. If remembering correctly its up under dash on drivers side. Not sure easly accessed...However the module boxes all mounted in my glove box. |
04-29-2014, 11:33 AM | #414 |
I'm sure it is either in the fuse box area, or in the kick panel. We can find it.
04-29-2014, 12:08 PM | #415 |
Drives: 2011 Camaro Convertible 2SS/RS Join Date: Mar 2011
I am probably doing something wrong, but I wanted to ask. I finally downloaded the Android app on my gS3, and told the app my system name. How do I get the wifi network to show up on my wifi list? Have a missed a step? I would like to stop carrying around 2 phones everywhere that I go.
04-29-2014, 12:25 PM | #416 | |
04-29-2014, 12:35 PM | #417 | |
Drives: 2010 Camaro 2SS/RS SLP Supercharged Join Date: Feb 2012
Otherwise, go back and verify your iPhone is still picking it up. |
04-29-2014, 12:38 PM | #418 |
Camaro CRAZY
I'll probably get the SJM kit for the ABL I remember seeing they had the kits for RGB now but were out of stock. I have like 3 spools of rgb lights I just gotta find where to put them. I'll be ordering a SL module today most likely for that. :-)
04-29-2014, 01:08 PM | #419 |
Drives: '16 2SS Join Date: Apr 2011
I've got them as out-of-stock now due to a backorder on light pipes. They should be shipped to us on Friday or Monday.
05-02-2014, 11:17 PM | #420 | |
KNGTFALL
Drives: 2012 2SS 45th edition Join Date: Aug 2012
well I finally got just about all my lighting done ( then you came out with the DRLs) LOL
It will never end. so far I have 1 HP module, 2 SL modules, 3 LP modules and some other LED stuff going on. For those waiting to pull the trigger, this is the best system on the market. and so easy to expand and add on to. Joe, I can't wait to see what you come up with next. Here is my Night Owl setup(99% anyway) on my car Knightfall. Hope you enjoy it! http://youtu.be/Inxsy0-b-Jk Last edited by GVA 45TH 2SS; 05-04-2014 at 10:35 AM. |
