Old 11-07-2018, 05:29 PM   #253
christianchevell
old school chevy rodder
christianchevell's Avatar
Just saying" theres a lot of intakes still even though we may seem like we are limited" and the LOD being one is sharp and not so ungainly in appearance covering the entire top of the engine with twin throttle bodies, though the tunnel ram effect is nice so it can be nice with many intakes. The word was on the Edelbrock that's what the coolest of applications of it would be for twin turbo twin throttle body set up as one would kind of look cool...… https://www.bing.com/images/search?q...s3&FORM=IQFRML
I have been here on this forum a long time, I was on the thread that would not die and finally has only to live someday again, it was called the Vararam VRX intake thread …...Like Moby Friggin Dick we were waiting to get a phenolic long runner intake to outdo the FAST and it just never got patented and never materialized ...and I was here..ROFL…..
https://www.lsxmag.com/news/vararam-...or-ls-engines/
There was no Luck to be found and production never commenced unfortunately for this one. Its good the LOD intake came out and others also as a true use would be more for Twin Turbo with a twin throttle body.... ..That's nice and symmetrical in appearance and the plumbing would be right there with improved flow for big potential and be cool for shows etc.... for example those pics from Bing, and others.
But the larger a intake also the larger its presence and ability to heat soak some also thus phenolic is nice but not always practical for higher performance … I am venting my hood just as is with the lack of engine weather strip in the middle cut out above the firewall but need more and will have to get ZL1 vent or aftermarket hood or hex vents some day myself.
I saw all that stuff on the Edelbrock long ago, I used to build all my old chevys with edelbrock intakes and valve covers and even some heads, but mostly Carter afb type carbs also, and intakes, and cams.
Think I kind think it as most its : Large and yup you don't see one under a Camaro hood, I would think its more for aftermarket LS install by like say 90%...but a engine that needs the increased flow ...best I would say one like mine a stroker even some aftermarket small bore ls7 and good 1.8 rockers....Bet it would sing.
The Vararam VRX they developed though had a good gain with it also for Torque....and its a shame they could just make Copo intakes and nothing for us...….Anyway that's a ramble, I have to run back to Get O.T. ,.... There were of course precursors to many things that eventually come down the pike or don't. The LOD is pretty and symmetrical and beefy and that's nice compared to maybe some lessor quality maybe sheet metal type intake.
The Edelbrock is like the Nelson so much larger than the LOD and twin TB....and there were precursors of larger leading to both's development I am sure having seen them.....
Yet costs versus effectiveness and appearance and practicality have not made the Edelbrock a common choice, more over extremely rare on here...Heck I might have seen one.....? over the years on here maybe.... But for many of us oldtimers on the thread from the dead dealing with the VRX it would have been nice to get to try the intake out !!!!!!!!!!!!!!!!!!!!!!its numbers sounded awesome for its design being different. Did not even take the time to read this article about the VRX sure I have read it before, but I hope you enjoy it. Would have liked to be a mule for the intake. But as always taste is subjective and if I did the twin TB I would have to go Twins..... gotta run.
Old 11-08-2018, 07:42 PM   #254
Drillteamleader
Drives: 2010 2ssrs
I ordered the new holley cross ram today. I will keep everyone posted if it fits and how it performs if so. If it doesnt fit, i will use it in my 84 regal.
Drillteamleader is offline   Reply With Quote
Old 11-08-2018, 10:26 PM   #255
13SSCamaro
13SSCamaro's Avatar
Drives: 2013 Camaro SS
Awesome, do you have dyno results of your current setup?
2013 SS M6, TSP Stage 3 231/246 cam kit, TSP Trunion upgrade, Cold Air Inductions CAI, VMAX PTB, TSP 1 7/8 Long tube headers and high flow cats, Corsa Xtreme ZL1 Catback exhaust, Elite E2-X Catch can, Trick Flow Gen-X 255 heads milled 0.025 and valve job, GPI rod mod and ported intake, ID850 injectors,ZL1 fuel pump, Flex sensor and E-85, Mantic 9000 and 1LE 3.91 diff 512rwhp/462rwtq
13SSCamaro is offline   Reply With Quote
Old 11-09-2018, 05:59 AM   #256
Drillteamleader
Drives: 2010 2ssrs
Yup. 508hp and 449 tq. I hope ot fits!!!
Old 11-09-2018, 06:45 AM   #257
lazerlemonta
lazerlemonta's Avatar
Drives: 2010 C6 1LT
I dint see any vacuum ports on that intake. Curious to see what provisions they made and where.
2010 C6 JET STREAM BLUE
BOLT ONS TO THE EXTREME, GPI 281cc HEADS, Darth_V8r SPEC CAM, FAST 102 INTAKE, CRANK SCRAPER, QUARTER MASTER 7.25" CLUTCH, RPM 3.90 STAGE II DIF, Z51 Gear Set AND E85
Best ET 10.58 @ 131.8 stock heads and stock cam 453/445 SAE
10.62@134.82 GPI 281CC Heads, SS4 Cam and X1 Intake
Best 1/8 6.80@105.75
Best MPH 134.82
lazerlemonta is offline   Reply With Quote
Old 11-09-2018, 07:36 AM   #258
christianchevell
Yup drilling and tapping things on aluminum intakes sucks as it does with steel, and especially plastic. All require being careful. Do not see a Cross ram on Hollys site just mid and high rises etc...nothing like the Edelbrock cross or nelson , had a 76 Buick regal t-top once though...lol painted it metallic blue jacked It up and put a stinger scoop on it with Buick rally wheels....LOL Thing had crushed velvet blue interior and I got a drivers seat to convert from split bench to two buckets...LOL ah memories....
https://www.bing.com/images/search?v...=15&ajaxhist=0
Old 11-09-2018, 09:25 AM   #259
Drillteamleader
Drives: 2010 2ssrs
I didnt see any ports either, but it comes with the fittings. Might just not be in the pics.
Old 11-09-2018, 10:19 AM   #260
13SSCamaro
13SSCamaro's Avatar
What is your plan for syncing the throttle bodies?
Old 11-09-2018, 11:22 AM   #261
Drillteamleader
Drives: 2010 2ssrs
There is a controller that i would need, but looking into what options i have.
Old 11-09-2018, 12:51 PM   #262
2011WhiteSS
2011WhiteSS's Avatar
Drives: 2011 White 2SS
$400 with connectors.
2011WhiteSS is offline   Reply With Quote
Old 11-16-2018, 06:55 PM   #263
13SSCamaro
13SSCamaro's Avatar
Wheres the updates
Old 11-17-2018, 08:02 AM   #264
Drillteamleader
Drives: 2010 2ssrs
I had to cut into the wiper cowl and bend the wiper arms. It does have vacuum ports though. Slowly making progress fabbing everything back up.
Old 11-17-2018, 08:18 AM   #265
Drillteamleader
Drives: 2010 2ssrs
Its big!!!
Old 11-17-2018, 09:26 AM   #266
13SSCamaro
13SSCamaro's Avatar
Its big!!!
Damn it definitely makes a statement, looks awesome. Really interested to see what kind of improvement you gain.
