07-19-2019, 04:53 PM | #1 |
key sticking in ignition
key is sticking in the ignition on my 2015 RS.i have to shift back into gear after restarting the car then go into park and turn it off in order to remove the key.this happened before under warranty and the dealer replaced the shifter,but now its out of warranty and i dont feel like being soaked for 5-6 hundred bucks every two years.i remember a thread concerning removing the plastic collar around the steering column and clipping a wire or removing a pin but cant find the tread now.also wondering if i need to disconnect the battery before removing the plastic around the wheel so i dont set off the airbags by accident.anybody remember this thread?
07-19-2019, 07:17 PM | #2 |
Drives: A Sneaky Fast Camaro Join Date: Jun 2019
Pull the cover around the ignition switch and simply unplug the lock out solenoid. The switch on the shifter is worn. You can also simply put your hand on the shifter and move the release button a hair and it will unlock. Don't move the shifter just the release button.
07-19-2019, 08:30 PM | #3 |
Drives: 2024Camaro 2SS CE Convertible Join Date: Jul 2013
Mine turned out to be the thing in the console that tells it it’s in park. Had to have it replaced.
07-19-2019, 10:12 PM | #4 |
Drives: '23 LT1 A10 Join Date: Oct 2015
07-20-2019, 07:47 AM | #5 |
mission accomplished...thanks guys!
07-20-2019, 08:31 AM | #6 | |
07-20-2019, 05:40 PM | #7 |
First we had to worry about key staying in the ignition, now the damn thing won't come out.
07-20-2019, 05:55 PM | #8 |
gems the wife said"its a new car,you shouldnt have to work on it".at 4 years and 46,000 miles chevy wasnt going to pay for another shifter,i wont pay for one every two years either.
07-20-2019, 11:54 PM | #9 |
Drives: 2014 Camaro 2SS RS & Ground effects Join Date: Apr 2014
https://youtu.be/maPES2c51ck
Mine started to do that as well. I did what this guy did and now no more problems and get this it was a free repair.
Don’t walk in front of me, I may not follow; Don’t walk behind me, I may not lead; Walk beside me, and just be my friend.
MY BUILD LINK: http://www.camaro5.com/forums/showthread.php?t=484260 |
