BeckyD @ James Martin Chevy
Old 11-15-2017, 10:36 PM   #1
302Blue
302Blue's Avatar
Drives: 2017 Camaro V6 1LE
Part Numbers for LS V6 1LE Brake Pads vs. Base SS
I was looking to buy some of the Z26 pads that seem to be a decent go-to pad for less dust and similar performance.
Problem is I have the 2017 Camaro LT V6 with the 1LE pack. Meaning it shares suspension components with the Base 1SS, which suposedly includes the Base 1SS's 13.6" 4 Piston Brakes.
I thought this meant I could go and grab the same part numbers for the Z26's as on a Base SS, but according to Powerstop the rear brake pads differ from the V6 1LE to the SS. I don't see why they would as that means that the rear brakes are completely different from the Base 1SS model. Yet I was told by customer service they can only supply the front brake pads for my car, which means they think the rear brakes are not only different from the 1SS, but also the 1LS/1LT/2LT variants, which they all have part numbers for. So the V6 1LE rears brakes are completely unique to that model? That just doesn't make any sense to me, why wouldn't GM take the rear brakes from either the Base 1SS or other models?
My real question is has anyone bought from PowerStop for their V6 1LE or Non-SS edition with the 4 piston brake kit? And if so, what part numbers did you end purchasing/using? Did they seem to fit perfectly fine for the rear?
***Updated for Real Part Numbers***:
Part #'s for the V6 1LE:
F: Z26-1474A (Sound Dampeners) or Z26-1001 (No Sound Dampeners)
R: Z23-1914 (No Z26's available for single piston)
Part #'s for the Base SS:
R: Z26-1718
Last edited by 302Blue; 10-29-2018 at 04:35 PM. Reason: Finalized Part Numbers listed; Actually bought & tested all of them
302Blue is offline   Reply With Quote
Old 11-16-2017, 07:35 AM   #2
scottc
Central PA Camaro5 Club
scottc's Avatar
Drives: Hot Wheels
Our v6 1LE cars have the Brembos in the front only, not rear...
Hot Wheel SE # 343
scottc is offline   Reply With Quote
Old 11-16-2017, 05:53 PM   #3
302Blue
302Blue's Avatar
So then the rear brakes would just be the same as a regular LT or other Non-SS model right? Why would PowerStop be saying they're different then?
Old 11-17-2017, 02:39 PM   #4
PolynesianPowerhouse
Big Samoan ina little car
PolynesianPowerhouse's Avatar
Drives: 2016 camaro
they might not have done the updating on their site, or had no cars or way to verify fitment.
I have the brembo 4 pistons in the front and the single pistons in the rear. just have to by for the LT under most charts and drop downs when looking, and then get the SS fronts.
good side is they usually cost lower for a smaller pad...just sayin..
Don't sit around and watch everyone else live YOUR dreams...DO SUMPT'N
When I see posts asking "whats the best intake, exhaust, etc" .... the answer to that is like a grandfather telling his grandkids "if you put salt on a birds tail, it'll let you catch it" #ThinkAboutIt
"Winning Tip: Don't take my (or anyone else's) word for it. GO TEST IT!" - Dennis Grant
PolynesianPowerhouse is offline   Reply With Quote
Old 11-20-2017, 08:02 AM   #5
302Blue
302Blue's Avatar
Alright, I will try that then. Thanks for the help
Old 05-05-2018, 07:41 PM   #6
302Blue
302Blue's Avatar
Concrete PowerStop Part#'s
FYI for anyone with a V6 1LE:
Front - Z26-1001 (Z26-1474/A's have sound dampeners that will stick out of the back of the caliper, still would work if you don't care about them sticking out)
Rears - Z23-1914 (No Z26's available for single piston)
Old 05-05-2018, 07:58 PM   #7
Kairles
Kairles's Avatar
Drives: 2015 Camaro 1SS
The V6 1LE actually doesn't have "SS" brakes. Its the same 4 piston Brembos available on any LS/LT. But yes the front pads are the same. I've had the Z26 1474s on my car for about 4 months, weights/dampeners don't look that bad.
Kairles is offline   Reply With Quote
Old 05-07-2018, 02:59 PM   #8
302Blue
302Blue's Avatar
Yeah weird thing is everything I read just said the V6 1LE just parts binned the SS's brakes. Unfortunately, I didn't figure that out that wasn't the case until I went to replace my own with the Z26-1474A's (Thank God for Amazon's easy returns).
But do you think that the weight/sound dampeners actually do anything? I couldn't find anything online about their actual function versus having a brake pad without them
Old 05-07-2018, 09:50 PM   #9
Kairles
Kairles's Avatar
I heard people were complaining about brake noise on 5th gen SSs so GM added the dampeners.
Old 05-08-2018, 09:54 AM   #10
302Blue
302Blue's Avatar
Wonder why the LS 1LE's don't have them from the factory then. Not that I had any issues with brake noise without them...just if you're already putting those pads in the SS, why not move them over to the V6? Maybe the weight difference or something really negates the need for them?
Old 04-20-2019, 02:02 PM   #11
ddanj
Drives: 2018 1LS 1LE
Did anyone end up getting the z23 pads for the rear brakes? Any feedback?
2018 Garnet Red 1LS 1LE V6 w/Tech
1100 - 07/26/2017 | 4300 - 09/15/2017 at rail yard
3000 - 08/16/2017 | 4200 - 09/18/2017 shipped!
3100 - 08/19/2017 TPW 09/11/2017 | 4800 - 09/20/2017 train journey done
3400 - 08/25/2017 | 5000 - 09/22/2017 at the dealer, and picked up!
4300 - 09/12/2017 Built! VIN available
4B00 - 09/14/2017 move to rail yard
ddanj is offline   Reply With Quote
Old 05-26-2019, 06:44 PM   #12
ddanj
Just FYI, there is a Z26-1914 for the rear - I bought online and installed today.
Old 09-21-2020, 02:56 PM   #13
laz323
laz323's Avatar
Drives: '17 Camaro 2LT 1LE
How did those rear brake pads work out for you?
NIVEOUS
laz323 is offline   Reply With Quote
brake pads, brakes, powerstop, v6 1le, z26
