AWE Tuning
Old 12-16-2021, 04:31 PM   #1
michaels.2lt
Drives: 2020 Chevrolet Camaro 2LT V6
Angry URGENTLY Need help on Cadillac ATS Brake Caliper conversion
I’m doing a swap from my stock LT calipers to the BREMBO 4 pistons from the 2013+ Cadillac ATS. Does anyone know if I need different brake lines? Whether from the SS or the ATS? Supposedly the stock ones fit, but I’m struggling to connect the fittings to the calipers all the way.
Thanks for any info, I’m struggling hard lol
michaels.2lt is offline   Reply With Quote
Old 12-16-2021, 06:00 PM   #2
michaels.2lt
Looks like I’m just needing new crush washers or a new banjo bolt, but I can’t find those for the life of me. Ace Hardware, Autozone, Home Depot, nothing.
Old 12-16-2021, 10:59 PM   #3
michaels.2lt
Well, we tightened the brake lines down a little more, and she’s not leaking, we will see if that holds up!
Old 12-17-2021, 04:32 PM   #4
dpevans
Drives: 2024 Riverside Blue 2SS 1LE
I can't tell you about the CTS but on the Camaro the SS Brembo brake line is shorter than the stock LT and you can buy crush washers and banjo bolts from Napa. Make sure you have full range of operation on the brake lines and they don't bind up and you should be good to go. Be prepared to buy a pack of 10 though. take in the banjo bolt with you to get the correct size.
dpevans is offline   Reply With Quote
brakes, brembo, cadillac, camarolt
