Old 11-16-2020, 11:16 AM   #1
weatherman71
Drives: 2019 Camaro 2SS
19 2ss Cyl 3 misfire
turned the car off......started it back up......had a miss to it and a slight backfire...Cel was flashing, checked the code " Misfire detected cylinder 3"
Put a new plug in....swapped wires from another cylinder also swapped coils from cylinder 1. Misfire is still there..... it clears up with more rpms but at idle its the most noticable.
19 2ss A10 tuned with Flex fuel tune..... car has 29,8xx miles and has been perfect till now.
weatherman71 is offline   Reply With Quote
Old 11-16-2020, 01:40 PM   #2
RyanR623
Drives: SS A8, NPP, Red Hot
How long after the tune did this start happening? If it was long after it could be an injector.
RyanR623 is offline   Reply With Quote
Old 11-16-2020, 02:05 PM   #3
weatherman71
the car was tuned around 7000 miles..... so roughly 22k ago.
Old 11-17-2020, 11:54 AM   #4
RyanR623
I'd probably lean towards an injector since you checked spark. Since I'm sure the dealer would deny the warranty claim due to flex fuel and the tune, swap injectors with another one from that bank and see if that cylinder misfires.
Old 11-17-2020, 07:52 PM   #5
weatherman71
update took the car to the dealer....SOMEHOW i missed a burnt spark plug wire... i was sure i inspected it but mistakes happen.... new plug wire and the car is back home running perfect.
