12-13-2017, 03:53 PM | #1 |
50th Anniversary Vert
Borla S Type 140687 Install P12F0 P069E CEL
Had the S Type Borla installed (model 140687).
Next day the CEL comes on (P12F0 and P069E, among others). Any idea what is going on? Car still drives, but it does feel a little rough at certain speeds.
12-13-2017, 06:28 PM | #2 |
Drives: 2016 camaro 1ss Join Date: May 2017
I have the same exhaust setup except it’s the atak with no afm valves and got the same code p069e, when I had my car cammed I brought it to my shops attention and they monitored the fuel pressure throughout the dyno runs and said everything was normal, for whatever reason hp tuners wasn’t letting them tune out the code, they sent out a trouble ticket to them and are now waiting to hear back.
12-13-2017, 06:53 PM | #3 | |
12-13-2017, 06:57 PM | #4 |
Drives: 2016 Red Hot Camaro 1SS A8 Join Date: Jun 2016
Is it cat back or axle back? It seems like these problems happen typically with cat back. Probably exhaust leak. Go back and tighten the bolts first.
12-13-2017, 07:02 PM | #5 |
Cat back, talking it back tomorrow, hope its that simple.
12-13-2017, 07:13 PM | #6 |
12-13-2017, 08:03 PM | #7 |
Yes, taking it back to Cordes tomorrow am.
12-13-2017, 09:03 PM | #8 |
Drives: 2023 2SS Convertible Join Date: May 2009
Is your car an Auto with factory NPP? If it is, then the Borla system you have installed will throw codes because the NPP valves are not installed. I am not sure if the M6 will throw codes for that or not. Unfortunately, Borla was having issues with their AFM valve and might not have the correct X-Pipe available for you right now, you will have to call them and ask.
-Geoff
'12 2SS RS Convertible - Traded in.
'16 2SS Convertible - White on white, mag-ride, NPP, nav. Sold! '23 2SS Convertible -Same as above except orange. |
12-13-2017, 09:47 PM | #9 | |
12-14-2017, 10:52 AM | #10 | |
-Geoff
12-14-2017, 11:22 AM | #11 | |
I asked if NPP would still work, and was told it would (it doesn't on this model). "Thanks Steve - so do I need anything else to get my NPP to work after install? In other words, do I just do a straight swap and everything will work?" "I accutally havent fitted the atak myself personally but it should be a straight swap over sir" Not a happy camper today. ----- Spoke to Borla, and yep, I have the wrong application. I will need a tune to remove the codes.
12-14-2017, 11:38 AM | #12 | |
12-14-2017, 11:51 AM | #13 |
Drives: 2017 1SS/1LE Join Date: Sep 2016
To be fair, this is listed in the product description on the Borla website:
Does not include NPP Valves. This system has dual tips and will fit the vehicles equipped with Dual Mode Exhaust (NPP), but it does not include Dual Mode valves and is intended for vehicles with significant upgrades that require a larger diameter exhaust. |
12-14-2017, 12:00 PM | #14 | |
