07-08-2014, 01:13 PM | #1 |
50th Anniversary Vert
OEM ZL1 wheels on SS
I read some conflicting threads, so I want to confirm.
Will the OEM Zl1 wheels/tires fit an SS? Front - 20x10 with 285/35/r20 Goodyears F1 Rear - 20x11 with 305/35/r20 Goodyears F1 Some people suggest bulging, issues with handling etc. Will they work on an SS (not lowered)?
07-08-2014, 03:19 PM | #2 |
Drives: 2018 Camaro ZL1 Join Date: Jun 2011
Yes, they will fit just fine. You might have to tie back the rear brake cables with a heavy duty zip tie though.
As far as bulging? They are an aggressive fitment so the fronts are right at the top fender line. Some like that some prefer them to be tucked in more. Handling? They handle great! I have BFG Rivals rather than the Goodyear F1s and 285s in the back rather than the 305s but this pic should give you a pretty good idea what they would look like...
07-08-2014, 04:29 PM | #3 |
Drives: 1994 1LE / 2006 Z51 Corvette Join Date: Jul 2009
Yes, they bolt on with no issues at all. Like they said above, check your parking brake cable...not all of the cars need it tied back but some will.
If you want to save some $$ and put it towards the tires, we have our ZR28 wheel, in the same finish and sizes that look very nice on the cars! |
07-08-2014, 10:04 PM | #4 |
Thanks all - that helps.
Love the ZL1 wheels!
07-09-2014, 08:56 AM | #5 |
FreakyFast!
Drives: 2010 2SS/RS S/C NicKey #55 Join Date: Feb 2011
Nothing new here, but confirmation the ZL1 setup with the Goodyears fit fine. I did have to ziptie the break lines. Mine is lowered 1.4".
2010 2SS/RS #55 NicKey Stage 2S Super-Camaro custom painted by Pete (Mr. Showstopper) Build Thread: http://www.camaro5.com/forums/showthread.php?t=250743 |
07-09-2014, 09:31 AM | #6 |
#TeamBeckyD
Drives: 2017 HBM 2SS Convertible A8 Join Date: Aug 2008
hey also fit on the V6 models as well no issues.
#TeamBeckyD
**FIFTY HBM 2SS VERT** |
10-18-2019, 08:46 PM | #7 |
Drives: 2011 Camaro 2SS Join Date: May 2019
Did you use hub centric rings for the change of bore on the wheels?
10-18-2019, 09:59 PM | #8 |
Running 6th Gen 1LE wheels with 285’s all around with no issues. Same basic wheel.
Orange Krush II
05-25-2021, 05:11 PM | #9 |
Do you guys know what offset the wheels are front and back?
05-25-2021, 05:13 PM | #10 |
I am having a hard time finding proper fitment for wheels on my 2013 SS . Started autocross and want to drop the car down to race only 19" wheels from 20" and can't get a definite answer on what offset limits will work!?. Any help greatly appreciated!
05-25-2021, 05:39 PM | #11 |
+23 front and +43 rear for the 5th gen wheels.
04-19-2023, 08:54 AM | #12 |
Tire choices
I'm looking to install them on my 2015 SS...does anyone have tire recommendations if It is lowered 1"...(I am installing eibach lowering springs and struts) I like the 20x10 20x11 look of the zl1 wheels
04-19-2023, 10:17 AM | #13 |
Drives: 2010 Synergy Green Camaro 1LT Join Date: Jun 2019
04-19-2023, 04:08 PM | #14 |
The BBOMG fill-in husband
Drives: 2015 2SS/RS 1LE AKA V1LE Join Date: Aug 2010
Comes stock on the 1LE/SS 5th Gen
UPSTATE C5 MEMBER
