11-03-2016, 08:59 PM | #1 |
Drives: 2015 Z/28 Black Join Date: Nov 2016
Z/28 Smog Check - how to Get those tests running.
Hello Z/28 fans, I bought my car out of state (300 miles) with a CA emissions sticker, so, it passes the inspection, but, it fails the smog test because the monitors (tests) are not running yet.. I could not get the Evap and fuel tests to run, so, I went to the my dealer. I did get the oxygen sensor test to run.. The technician spent 20 min. with me and told me how to drive the car to get the tests to run. Great guy and great Dealership.
Bottom-line, you have to drive it opposite of the break-in procedure and that is why I can't get my tests running. 1. You have to be in "cold start". Overnight cold start. No faking this. 2. You have to start it, no gas, and let it idle for 2 min. 3. Drive it though town to the fwy for a few miles. Drive like a grandma, no air on, no punching it, no stereo, nothing to disrupt the test. Try to keep your speed constant. No fast moves. 4. Get on the fwy, drive 5 miles at a constant speed, preferable in the same gear. Should between 55 and 70. 5. Get off the fwy, turn it off for 10 min. 6. Drive normally back home. Doing this procedure should get your monitors (tests) running so you can pass smog. In the 230 miles that I drove my Z/28, I never drove it like that... I will update this thread when I get all my tests running. Last edited by hjdca; 11-03-2016 at 09:15 PM. |
11-03-2016, 10:15 PM | #2 | |
Drives: 15 RH Z/28, 23 RB2SS1LE, 23LT1VOM Join Date: Dec 2012
11-05-2016, 06:27 PM | #3 |
Update... I did this procedure twice, the second time with 20 miles constant on the fwy. The smog fuel test started running.. only Evap is still not running, but, it is not needed for the smog certificate. I went back and they passed the car and gave me the smog certificate. I am good to go ! Great guidance from GM Smog Tech at the Dealer ! Thanks !!
11-05-2016, 06:36 PM | #4 |
Drives: 20 X3M CP & 19 ZL1 1LE A10 Join Date: Jun 2013
CA. <--- A joke state.
🔺22 RS E TRON GT
🔺21 Model S Plaid |
11-11-2016, 06:45 PM | #5 |
Drives: 20’ Chevrolet Camaro 2SS 1LE Join Date: Jan 2009
You're the joke. Lol. You TX chumps are always talking shit. Must be a "small hands" thing?
11-12-2016, 08:22 PM | #6 |
At least we have turns and canyons to carve..... and trees and hills to look at...
Honestly, before CATS came in 1976, smog alerts all the time in LA... Then, by late 80s or 90s all the smog was gone.... LA and the Valley are so clear now all the time.. So LA needs CATS in cars.., but, Except of course in my 70 Chevelle SS396, no Cats... Buy 1975 or earlier in CA and you can do what ever you want to your engine... No worries... Hate to say it, but, CATS is the best thing that every happened to LA..., but, I like the lope, sound, and smell of my Chevelle... Last edited by hjdca; 11-13-2016 at 10:27 AM. |
11-12-2016, 08:28 PM | #7 |
Oh.
🔺22 RS E TRON GT
🔺21 Model S Plaid |
11-13-2016, 04:48 PM | #8 |
Life Is Short Enjoy It!
Drives: Original Owner 15 Z/28 #934 Join Date: Sep 2016
Thanks for posting this information - we just picked up two cars from out of state, both with CA emissions that we have to get registered. Both are new - so will be interesting to see if we have to get smog with original MSO in hand.
11-13-2016, 06:35 PM | #9 | |
1. Before going to the DMV, get a smog certificate. The DMV will make you go back and get it anyway and you have to wait in line twice... You need the actual paper certificate, it is not an online transfer of data. The sticker under the hood with the California numbers is required by the smog place.. 2. Before doing the actual test, ask the tech guy to hook up the code reader and make sure all the test are running. This way you will not fail the test, and it will cost you another $10 for a retest.. Note: I had three tests that were not running - EGR, Fuel, Evap.. 3. If any of the test are not running, just follow the procedure above, it works perfectly and all my tests were running pretty quickly after I started following the procedures. 4. When you go register at the DMV , they will do a visual inspection. They check for the sticker under the hood with the CA numbers and the VIN. 5. Mine was untitled, with 300 miles, and bought from a dealer out of state, -- and the DMV required -- a signed Certificate of Origin, Bill of Sale, Odometer reading declaration, and a smog certificate.
2015 Black Z/28
70 Chevelle SS396 01 M3, 88 Land Cruiser Last edited by hjdca; 11-14-2016 at 07:02 PM. |
11-06-2023, 08:38 PM | #10 |
Drives: Z28 Join Date: Mar 2023
Tried it for just under 400 miles, did the drive cycle many times. O2 and Evap still won't set, car is all stock :(
11-07-2023, 09:50 AM | #11 |
Drives: '15 Z/28 Join Date: Nov 2021
My state requires 2 of the 3 to be set to run through the emission test. This is how I was able to get mine to pass. One of the 3 I set after attempting various "drive cycles", my GM technician friend Forced another with the GM service tool, and so I had 2 of the 3 to run through the test. This all happened after a battery change on a 100% stock car as well.
11-07-2023, 05:18 PM | #12 |
Life's just a Ride
Drives: 2011 Synergy Camaro 2SS/RS LS3 Join Date: Oct 2013
and many more
But go to Germany and try to pass the TUV Just a little rust anywhere and you fail. |
11-07-2023, 10:12 PM | #13 |
It hit 500 miles on the odometer and my scanner beep, O2 is set!!!!!!!!!!!!! Finally can pass smog
