Go Back   CAMARO6 > Engine | Drivetrain | Powertrain Technical Discussions > Tuning / Diagnostics
AWE Tuning
Old 05-30-2018, 10:14 PM   #1
EMTNLSS
EMTNLSS's Avatar
Drives: 2016 Hyper Blue 2SS
Help with HPTuners Active Exhaust valve control
In HPTuners I see under System > General that's there a Active Exhaust section. Has anyone messed with these to see if it changes when the valves open or close? I want to see if when it's in Track mode I can make them stay open all the time. I know I can pull the fuse for them but I would prefer to be able to put it in Stealth in the mornings when i leave then Track anytime else.
2SS Hyper Blue Metallic | A8 | Jet Black Interior | NPP Exhaust
Current Mods: Catch Can | aFe Lowering Springs | GM 2nd Gen Splitter | Hotchkis Sway Bars | MRR FS02 Wheels | Flowmaster Exhaust | Dark Tail Lights | Diode Dynamics Sidemarkers | Roto Fab | Solar TB | PRAY Ported IM | BMR | PRAY Tune
Upcoming Mods:
EMTNLSS is offline   Reply With Quote
Old 06-05-2018, 09:16 PM   #2
EMTNLSS
EMTNLSS's Avatar
So I changed Exhaust Valve Enabled to Disabled and it disabled them. I would change the modes between Stealth and Track and they would stay open. So it definitely affects them. I just don't know what any of the tables mean and what to change on them. I guess i'll continue logging them and messing with them and see what happens.
Here's what some of the tables look like.
Upcoming Mods:
Old 06-16-2018, 09:13 PM   #3
EMTNLSS
EMTNLSS's Avatar
Update to this. HP Tuners was updated to read all the channels for the valves so you can see what table it's using and what row and column is being used in that table. You have to be on the latest beta to see these. There should be a update next week sometime that relabels everything better.
I've tuned my track mode to be open all the time except in 8th gear so when i'm on the freeway it quiets down and reduces the slight drone I get.
Upcoming Mods:
Old 06-16-2018, 10:41 PM   #4
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
I was wondering why... but you just explained in your last post. Good stuff.
Old 07-10-2018, 09:34 AM   #5
crosive
Drives: 18 zl1
crosive is offline   Reply With Quote
Old 07-10-2018, 06:07 PM   #6
cmitchell17
Drives: 17 2SS, 8L90, Cam, Heads, E85
I'm kind of confused now, you said it was in system, but I thought you had to pull the flash from the FSCM and reflash for these tables? So you would need to license the FSCM? Or is it on the PCM? I don't see it on my 2017? I think I heard something about it changed on the 2017s to where it is on the FSCM? I guess that's another way the 2017s got screwed over besides the TCM security haha
cmitchell17 is offline   Reply With Quote
Old 07-18-2018, 11:39 PM   #7
BlueCamaro6
BlueCamaro6's Avatar
Drives: 2018 Camaro 2SS, Hyper Blue
Did you figure out how the table data works the exhaust?
2018 2SS, A8, NAV, NPP, MRC, Sunroof, Hyperblue, LT4 S/C, LT4 Fuel System, RotoFab CAI, Headers, HiFlo Cats
2016 2SS, A8, NAV, NPP, MRC, Sunroof, Hyperblue (GM buyback)
1999 Trans Am Firehawk, M6, headers, no-cats, slp exhaust, hot cam, intake, 3:73 gears. Red/Blk
BlueCamaro6 is offline   Reply With Quote
Old 07-23-2018, 12:46 PM   #8
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
I can not gain access to these tables. I am on the latest HPtuners Beta 4.1. It's not showing up under system/general?
2016 NFG 1SS A8
Options-2SS Leather/NPP
Old 07-23-2018, 02:07 PM   #9
EMTNLSS
EMTNLSS's Avatar
Maybe try reading the car again with the latest beta.
Upcoming Mods:
Old 07-23-2018, 02:21 PM   #10
KingLT1
KingLT1's Avatar
Ok...that is what it probably is. Thanks
2016 NFG 1SS A8
Old 07-27-2018, 07:30 PM   #11
KingLT1
KingLT1's Avatar
Have mine tuned now...thanks for the heads up!
2016 NFG 1SS A8
Old 08-03-2018, 06:32 PM   #12
cmitchell17
But we need to license the FSCM to have access to the tables right? Or are you getting access through the PCM?
Old 08-04-2018, 12:28 PM   #13
KingLT1
KingLT1's Avatar
There is no PCM...ECM/TCM/FSCM. Yep you need to license the FSCM which is 1 credit(50.00). It's well worth it imo to have control over the NPP valve function. The exhaust sounds much better not fluctuating open and closed at different tps percentages/rpm/gear all the time. I have Touring set closed with Exhaust startup Rumble disabled and both Sport/Track set open under all conditions.
2016 NFG 1SS A8
Old 08-04-2018, 06:15 PM   #14
BlueCamaro6
Yeah, I licensed mine and feel it was well worth it. Exhaust stays open when I want, closed when I want, etc. I always hated the track setting quieting it down when driving. I like exhaust noise, especially when it sounds good. I did headers, hi-flo cats, mid-pipe, to the NPP.
