View Poll Results: Headers rubbing on steering shaft? | |||
Kooks 1 7/8" Yes | 2 | 3.92% | |
Kooks 1 7/8" No | 12 | 23.53% | |
Kooks 2" Yes | 2 | 3.92% | |
Kooks 2" No | 5 | 9.80% | |
Texas Speed 1 7/8" Yes | 13 | 25.49% | |
Texas Speed 1 7/8" No | 5 | 9.80% | |
Texas Speed 2" Yes | 8 | 15.69% | |
Texas Speed 2" No | 4 | 7.84% | |
Voters: 51. You may not vote on this poll |
Thread Tools |
05-13-2018, 03:19 PM | #1 |
Drives: 2016 Hyper Blue 2SS Join Date: Feb 2016
Header rubbing steering shaft poll
I'm debating on if I want to get Kooks or Texas Speed 1 7/8" or 2" headers and want to know who has rubbing with any of these options even with the steering shaft bolt replaced. I probably don't need the 2" as the most I ever plan on doing is a smaller cam down the road but i'm just curious who has the rubbing issue.
2SS Hyper Blue Metallic | A8 | Jet Black Interior | NPP Exhaust
Current Mods: Catch Can | aFe Lowering Springs | GM 2nd Gen Splitter | Hotchkis Sway Bars | MRR FS02 Wheels | Flowmaster Exhaust | Dark Tail Lights | Diode Dynamics Sidemarkers | Roto Fab | Solar TB | PRAY Ported IM | BMR | PRAY Tune Upcoming Mods: |
05-13-2018, 04:03 PM | #2 | |
Drives: 2017 M6 2ss, Sunroof, Silver Ice Join Date: Apr 2018
05-13-2018, 08:53 PM | #3 |
Drives: 2016 Camaro 2SS Join Date: Mar 2016
ARH 1 7/8th no rubbing
2016 Hyper Blue 2SS A8,NPP,Moonroof
Pray ported factory intake manifold Ported TB Rotofab ARH 1 7/8 longtubes hi flow cats AFM deleted E85 11.0@124.9 11.65@118.8 pump gas,stock tune/exhaust New combo: Pray Performance Heads/cam MSD intake manifold and Circle D 3C 554/491 on E85 all work & tuning done by Pray |
05-14-2018, 06:25 AM | #4 |
Kooks 1 7/8. No rubbing and tons of clearance with the oem bolt
Baby Blue
05-14-2018, 10:09 AM | #5 |
Drives: 2018 zl1 1LE Join Date: Mar 2017
X2. There’s a ton of room between the shaft and the tubes with the kooks setup.
2018 ZL1 1LE
2021 GLS63 AMG 2005 SRT4 2017 Ram 1500 |
05-14-2018, 10:51 AM | #6 |
Drives: 2017 Camaro 2SS Join Date: Mar 2017
i replaced the bolt and no rub.
2017 NGM 2SS NPP M6 MRC Vortech SC, 2" TSP LT No Cats, Borla X, Eibach, Hurst shifter 603hp/547tq |
05-14-2018, 11:07 AM | #7 |
There's plenty of clearance everywhere with kooks 1 7/8 long tubes. I didn't have to relocate or otherwise mess with the wiring harness on the right side either
Baby Blue
05-14-2018, 11:20 AM | #8 |
Drives: SS 6 speed of course Join Date: Jan 2016
my OEM bolt has a small head and it barely sticks out of the backside's weld on nut. I don't know how there is a "smaller bolt" made. please send me some info on it?
05-14-2018, 11:26 AM | #9 |
Hey EMTNLSS, I believe a similar poll for post header exhaust leaks would be of interest to members. Even the slightest leak will trigger a CEL if the O2 sensor sees it. Lots of guys have given up on getting a 100% seal at this connection and have welded the connection between their headers and cat/connection pipe. I would submit the poll myself if I was tech savvy enough to do so.
I installed Kooks 1 7/8 long tubes. I aligned my headers and cats perfectly before torqueing the ball and socket clamp to the Kooks recommended value. I started getting intermittent CELs and upon further investigation, noted some very slight soot marks at on the headers adjacent to the clamping bolt on the ball/socket clamp. It should be noted that this leak is so slight, you cannot detect it with the car on a lift, listening with an improvised stethoscope (heater hose). The leak is that small, but it is enough to cause CELs on these cars.
Baby Blue
05-14-2018, 02:29 PM | #10 | |
05-14-2018, 07:06 PM | #11 |
Drives: 2018 Silverado Z71 TxEdition Join Date: Dec 2017
I literally just got the new bolt from russell at texas speed 2 wks ago. the quickest fix for the lower bolt replacement. been dealing with this for over 8mths after having TSP headers installed. 25 cent bolt for the win!!!!!
i posted pics on my IG if yall wanna see. @FIFTY017 |
05-14-2018, 09:21 PM | #12 |
Drives: 2016 2SS, HBM, NPP, Sun Roof Join Date: Jun 2013
Texas speed 1 7/8 no rub
05-14-2018, 11:03 PM | #13 | |
SS Copbait R.I.
Drives: 2016 Camaro 2SS Join Date: Dec 2016
05-15-2018, 10:19 AM | #14 |
Drives: 2017 2SS M6 Join Date: Jun 2013
ARH 1 7/8" no rubing
