06-13-2017, 11:46 PM | #1 |
Drives: 2016 Hyper Blue 2SS Join Date: Feb 2016
Looks like a new rear caliper upgrade kit is coming soon
Saw this on Chevrolet Performance Instagram story.
2SS Hyper Blue Metallic | A8 | Jet Black Interior | NPP Exhaust
Current Mods: Catch Can | aFe Lowering Springs | GM 2nd Gen Splitter | Hotchkis Sway Bars | MRR FS02 Wheels | Flowmaster Exhaust | Dark Tail Lights | Diode Dynamics Sidemarkers | Roto Fab | Solar TB | PRAY Ported IM | BMR | PRAY Tune Upcoming Mods: |
06-14-2017, 01:00 AM | #2 |
#becauseracecar
Drives: 2016 SS Sedan, 2016 Camaro SS Join Date: May 2015
I'm looking at a photo of that one and a photo of the stock SS caliper and they look identical except for the color. I wonder if it will just be a color upgrade to match the fronts on the optional 6 pot setup. Especially because it says caliper upgrade but nothing about disks.
06-14-2017, 01:23 AM | #3 |
My guess it might be for the LS/LT Camaros so they can have the matching SS rear brakes if they want along with the 4 pot front brake upgrade.
06-14-2017, 02:22 AM | #4 |
Drives: 2LT Fifty Join Date: Jan 2017
I hope they also make them in orange to match the front on a 2LT Fifty.
06-14-2017, 05:04 AM | #5 |
Big Samoan ina little car
Drives: 2016 camaro Join Date: May 2014
read the plaque below it... it says LS, LT, ...... so this is prob the fix/upgrade for the parking brake prob.
Don't sit around and watch everyone else live YOUR dreams...DO SUMPT'N
When I see posts asking "whats the best intake, exhaust, etc" .... the answer to that is like a grandfather telling his grandkids "if you put salt on a birds tail, it'll let you catch it" #ThinkAboutIt "Winning Tip: Don't take my (or anyone else's) word for it. GO TEST IT!" - Dennis Grant |
06-14-2017, 05:33 AM | #6 |
Drives: 2017 Camaro 2.0T RS Join Date: Jul 2016
My prayers have been answered!
As Delivered: 2017 Mosaic Black 1LT RS 2.0T | M6 | HD brake and cooling | Bose & 8"screen | Front lip extension | Blade spolier | Black bowties | Painted splash guards
Installed Mods: 25% Window tint | Headlight, side marker and third brake light Phastek tint kit | GM black taillights with Gen5diy LED harness and bulbs | LED license plate bulbs | Gorilla lug nuts, black | GM 'performance' center caps | RS and sheild badges removed |
06-14-2017, 06:34 AM | #7 |
Drives: 2016 Camaro LTG Join Date: Jul 2016
Interesting... I wonder how they will solve the parking brake problem.
2016 LTG Camaro in Hyper Blue with MRT V3 Catback and Brembo SS Brakes.
06-14-2017, 07:30 AM | #8 |
My guess is the new caliper has an addition to attach the parking brake plug addition. Like a bracket
06-14-2017, 07:41 AM | #9 |
Drives: Overkill Supercharged 2016 CamaroV6 Join Date: Mar 2016
Great NEWS!
06-14-2017, 09:26 AM | #10 |
#becauseracecar
06-14-2017, 10:43 AM | #11 |
My bad.
06-14-2017, 11:06 AM | #12 | |
Drives: 2016 1ss Camaro Join Date: May 2016
Andrew Bettridge
Account Manager Extreme Dimensions 1-714-278-8000 EXT 17 andrew.bettridge@extremedimensions.com |
06-14-2017, 04:36 PM | #13 |
Damn... :(
06-15-2017, 06:44 PM | #14 | |
The way the current one works is an electronic lever actuator to twist and press thru the caliper to piston and the caliper slides to pinch the rotor.. If Brembo made some type of machining to it to allow that on one of it's pistons, but one out of 4 (as the caliper does not slide), not sure that would work, as it would need the piston on the other side to move in also to actually pinch the rotor. They would also have to make either an entirely new casting with the proper length and spacing of the caliper mounts or create a adapter bracket to connect to the shorter and closer mount holes on the RS knuckle. Only other way would be a huge conversion package of everything to do a complete swap to the SS style or maybe a electronic motor/ fluid lock valve to create a way to lock the pressure in the caliper and lock it, but normally they want a mechanical brake separate of the fluid brake system. |
