03-19-2019, 08:01 AM | #1 |
Drives: 17 Camaro SS 1LE & 16 Sierra AT CC Join Date: Nov 2016
2017 Camaro SS 1LE w/ Procharger D1SC
I had this car set up last year, for the most part it seems to drive fine. Putting down 650rwhp on a consevative tune with a Alky controls meth injection system.
It had some surging and bucking issues. I took it back down to the shop that did the install and had them swap out the 1.5" PC BOV for a 2" Tial BOV. They went thru the tune and made some changes to the VVT tables that resolved the bucking/surging. Got the car home and a nagging issue still persists. From a dead stop if I let the clutch out and accelerate at a moderate pace some form of torque management is stepping until around 3500-4000 rpm's. When it stops it is like the car comes on like a raped ape. I have checked anything and everything mechanical and it's nothing mechanical. A member on the HPT forums overseas said the car has to use a LT4 map, which I asked about to Procharger and the shop and was told I didn't need one. The member pointed out the torque models were off, which they are since they are the stock SS 1LE tables. Anyone in here that went Procharged, did you change out the LT1 map for the LT4 map? Pray or Jannnety, can either one of you chime in on this? I am more than willing to pay for the help. I have tried getting the shop involved, it's a 4hr drive to them so that isn't the easiest way right now.
2019 Corvette Z06 2LZ A8 - Halltech CAI, AWE non-catted X-pipe, Mamo V2 ported TB 592rwhp, bone stock 566rwhp
2017 Camaro SS 1LE - Procharger D1SC w/ Tial 2" BOV & Race intercooler / ARH full length catless headers / Alky meth injection system - 650rwhp on conservative tune SOLD |
03-19-2019, 09:04 AM | #2 |
www.jannettyracing.com
03-19-2019, 09:14 AM | #3 |
Drives: 2018 Audi TT RS Join Date: Jan 2014
You know what’s funny, is that my car isn’t boosted but it does the same thing. Even with all of the torque management essentially turned off. It’s incredibly frustrating. It’s like the car is dragging an anchor and then suddenly at 3-3200 rpm, it pulls stupid hard.
2018 Audi TT ▊RS
2.4X 0-60, 1.6X 60', 120+mph 1/8th, 4.XX 60-130, 150+mph traps on 255/35/18 R888R tires on the street (unprepped). 2019 Audi RS3 About as fast as the TT RS 2019 Camaro ZL1 1LE Sold 2018 Camaro SS 1LE Sold 2019 Corvette Z06 Sold 2021 Charger Hellcat Redeye Widebody Sold |
03-19-2019, 09:34 AM | #4 |
Sounds tuning related.
2016 NFG 1SS A8
03-20-2019, 06:53 AM | #5 |
I am sure a portion of it is as well, but the shop that did the install and tune has become non-responsive now. I guess my $15k build they did isnt as important as their $40k customers builds.
01-04-2020, 04:13 PM | #6 |
I’m having this same issue with a procharged 16m6. What is the fix?
01-04-2020, 05:37 PM | #7 |
Drives: SS 6 speed of course Join Date: Jan 2016
Other people may have other experience, I have always had drivability issues with no cats, both with the stock header and LT. In all cases cats fixed my problem. Even when this car was NEW, early 2016, going to CA cat deletes would cause strange harmonics and on a few cars would pull timing due to false knock (assumed). Anyway with no cats low speed driving and part throttle tip-in was soggy as well as strange drone / sound harmonics. That would be 3 professional well known tuners and myself and when new, GM (only thing I turned off was the rear 02 monitoring). In my opinion, it is a harmonics issue with the M6 and no cats.
I will by spring do mandrel bent 2.5 from factory header to 2.5 metal cats directly horizontal, to Borla 60608 twin resonators at 2 and 3/4, to see if I can finally find a reasonable flowing solution with 100 percent stock drivability on a M6. In all cases, car works 100 percent fine with primary cats.
01-06-2020, 12:08 PM | #8 | |
A crappy tune from the shop who handled my Procharger install. They are drag racers and the tune was built more for drag racing than driveability. Ted found it in the 1st revision of his tune, it was torque management kicking in that wasnt addressed in the tune from the shop that handled the install. Car drives great now.
01-06-2020, 06:19 PM | #9 | |
Drives: 2002 z28, 2018 2ss 1LE Join Date: Sep 2012
Thank you t |
01-06-2020, 06:38 PM | #10 |
Good to hear
01-07-2020, 07:33 AM | #11 |
Good Morning Z28pat, Please feel free to call me I can answer all of your questions, write you an estimate and recommend the best combination for your car and your goals 203-753-7223
01-07-2020, 07:43 AM | #12 |
Drives: 2017 Camaro SS 1LE (F1A-94 FBO H/C) Join Date: Jun 2017
sounds 100% like a tuning issue, its hard now a days to find reputable tuners for these 6th gens. Jannetty is ready to help so i'd give them a call for some great customer service!!!
Performance Mods: F1A-94, DSX Flex Fuel Kit, MSD Spark Plug Wires, KOOK 2" off road headers, MBRP Race catback exhaust, Pray Performance Custom Boost Cam, Rocker Arm Trunion Upgrade Kit, 7.850" Hardened Chromemoly Length Pushrods and Johnson Racing 2110R Lifters, TSP CNC'd Heads, Ported MSD intake manifold, 103mm Katech Throttle body, Forged Pistons/Rods, RPM Meth kit, DSX Aux Fuel system, AEM Failsafe and banks gauge, LT4 HPFP, LT4 injectors, BMR motor mounts, Hurst Short Throw, Manley SS exhaust valves
Videos of my car? Check here: https://www.youtube.com/channel/UCNi...Qy1OL4NVGlPogw |
01-07-2020, 01:30 PM | #13 |
You build is similar to mine, so you can put your car into 5th at 42 MPH and there it works just fine, sounds fine etc?
01-07-2020, 01:41 PM | #14 | |
the one provided for my F1A setup isn't large enough to go over the KATECH. If possible can you send / attach a pic, i might need to alter mine a bit to make it work.
