dave@hennessey
Old 07-30-2012, 05:11 PM   #1
jlugo
Drives: 2014 1LE 'Summit White'
08-09 Pontiac G8 Gear's will fit the Camaro?
Are the 08-09 Pontiac G8 and the 2009 up Camaro gears similars? Will they fit my Camaro SS?
Pontiac G8;
Motive Gear 3.90:1, 32-spline Pinion, 10-bolt, GM 218mm (MGR-GZ85390)
http://www.summitracing.com/parts/MGR-GZ85390/
Camaro;
Motive Gear #683-G886391 GM 10 BOLT 8.6 3.91-2009 UP Camaro
http://www.jegs.com/i/Motive+Gear/683/G886391/10002/-1
jlugo is offline   Reply With Quote
Old 07-30-2012, 05:14 PM   #2
Driveshaftshop
Driveshaftshop's Avatar
Drives: own more cars than i can list
no i dont believe so, the G8 has a diff made by ZF. the Camaro was made by American Axle
Driveshaftshop is offline   Reply With Quote
Old 07-30-2012, 05:33 PM   #3
jlugo
The small G8 diff will not work in the Camaro, but the Camaro center section fits in the G8. Some g8 guys are replacing the whole rear end with camaro rear ends!
http://www.g8board.com/forums/showth...t=30698&page=2
Old 07-30-2012, 06:18 PM   #4
GFORCE1320
Drives: 05 GTO
The G8 gears have a slightly smaller ring gear then the Camaro and will not fit. We tore both apart when they first came out and found this out.
We were also the ones to test fit one of the first Camaro centers into a G8 to find that it fits perfect.
Now here is another option for Camaro guys.
Wavetrac has come out with a posi for the G8's and the G8 rear will bolt right up to the Camaro. The Camaro inner stubs, axles and driveshaft bolt right up.
We will have the G8 Wavetracs available later this week if anyone is interested.
Thanks
Chris
GFORCE1320 is offline   Reply With Quote
