02-28-2024, 04:34 PM | #1 |
Drives: '23 LT1 & '16 GMC Canyon Join Date: Feb 2023
LT1 tire suggestions
I have a '23 LT1. Had a nail pulled and plugged the other day. Got me thinking about when the time comes for new tires. I would stick with the stock size. What have you other LT1'ers done?
02-28-2024, 08:12 PM | #2 |
Drives: '23 LT1 A10 Join Date: Oct 2015
If I were to stick with the current size I'd go with a summer tire such as the Continentals
24 LT1 M6 Sharkskin Metallic
02-29-2024, 07:02 AM | #3 |
Depends on what you want and how you drive, the range from an A/S because you just putter around in a D/D year round, or, you want to throw gears and race the streets in the summer but need to have some winter use if you don't have a dedicated winter tire...you're gonna have to say a little on what you want from a tire.
02-29-2024, 07:15 AM | #4 | |
Drives: 2023 Camaro LT1 M6 Join Date: Dec 2022
OP - Since you are on OEM All-Season Run-flats now, are you good with going with non-run flats to get better tires? And do you need all-seasons? If yes to both questions, I recommend the Continental Extreme Contact DWS06+ that I and many others have for a top high performance all season. However, as havelegs noted especially if you stay with current all 245 sizes then you should consider going with high performance summer Continental or Michelins option that will get you some more traction & grip for launches.
2023 Black LT1 – M6, Dual Mode Exhaust, Sunroof, Tech Pkg w/Bose Audio, Red Front Brake Calipers, Carbon Flash Wheels, Ground Effects & RS Pkg
Added after delivery: Continental ExtCont DWS06+ Tires: 245/40/20 Front & 275/35/20 w/9.5” Rear Wheels, Red Rear MGP Caliper Covers |
02-29-2024, 08:05 AM | #5 |
the OP is in "Hellafornia," so he doesn't need all-seasons. The Conti ExtremeContact Sport or Micheline Pilot Sport 4S are the two obvious recommendations for a "three-season" extremely-high-performance tire. That said, I agree that it would be helpful to know how he uses the car and what his priorities are.
Matt Miller
2020 SS 1LE |
03-08-2024, 12:56 AM | #6 |
I don't track or push the limit...just general driving. I would stick with all season run flats.
03-08-2024, 07:24 AM | #7 | |
Looks like you only have your current OEM Goodyears for all season run-flats to pick from. If you can go with summer performance tires since you are in California, there are some Pirelli Pzero PZ24 summer run-flats that are rated somewhat better than the Goodyears.
03-09-2024, 08:51 AM | #8 |
BTW - If you do want to stay with All Season and run-flats anyway so you want to get another set of OEM Goodyear all season run-flats, this is your lucky day!
There are plenty of Camaro owners on this site that replace these tires to get better non run-flats and not many buyers - put a WTB add in classifieds and you should be able to pretty easily find people willing to give you a good deal on their take-offs. Good luck!
Added after delivery: Continental ExtCont DWS06+ Tires: 245/40/20 Front & 275/35/20 w/9.5” Rear Wheels, Red Rear MGP Caliper Covers Last edited by BatMobileLT1; 03-09-2024 at 09:15 AM. |
04-09-2024, 08:28 AM | #9 |
Drives: 2021 LT1 6spd Join Date: Nov 2020
Firestone FireHawk Indy 500, excellent tires on a new set of wheels.
Plan to replace the OEM A/S with a better set when they're finally done.
Current: 2021 LT1 Camaro, 6spd, Crush, Corsa NPP, GMPP CAI, Soler Performance Throttle controller
Previous: 1997 V6 Camaro, 5spd, Black |
