12-02-2015, 11:44 PM | #1 |
Drives: 2011 Camaro SS/RS Ground Effects Join Date: Oct 2015
Just installed LTs with tune but taking to dealer. Why to return to stock tune?
I just installed a set of Stainless Power Long Tube headers with high flow cats. I have an SCT X4 tuner that I use to tune my vehicle for these LTs. I have to take my car in soon to get new tires on it. Why do I have to return it to stock tune when taking it to the dealer and will this harm my engine with the LTs on it if I only leave it stock tuned while it's at the dealer? I have heard that leaving it stock tuned will cause the engine to run rich but would it hurt it to leave it stock at the dealer just long enough for them to put on tires?
12-03-2015, 02:21 AM | #2 |
Drives: 2015 Yellow 2SS LT Z28 cai tune Join Date: Aug 2015
subscribed. i'm in the same situation
12-03-2015, 03:28 AM | #3 |
Drives: 1LE Join Date: Feb 2013
Why bother? They are likely not going to put it on the computer if you are only getting tires. And if they did care that much, they will obviously see the headers anyway and bust your chops for it with or without a tune.
I'd be more concerned that someone would take it for a joy ride and hit it hard with a tune that is not calibrated for your modifications . . . |
12-03-2015, 05:49 AM | #4 |
Homeless Life Chose Me
Drives: LS3 (sold 4/21) Join Date: Nov 2014
No you can drive it for a year without a tune and nothing will happen. And why would you care about your tune just for changing tires?? Makes no sense your not getting warranty work or anything. And if u are your already screwed since you tuned it! They can see even if your return it to stock.
Pity a man in familiar places, who yet feels like a stranger.
12-03-2015, 05:58 AM | #5 | |
Too much is never enough!
Drives: AGP TT SS [COTW] 4/20/15 Join Date: Feb 2014
And Welcome to C5!
AGP TT kit, 54/57 Forged rotating assembly, Custom grind cam... Dual nozzle meth, ID850's, Livernois dual fuel pumps, ECS BAP, 25% UDP, 3 inch Magnaflow catback with X pipe, Mantic 9000 clutch, DSS 1000hp axles, DSS aluminum driveshaft, ZL1 rear end, solid subframe bushings, HE differential offset bushings, BMR Trailing arm, BMR toe rods, Lingenfelter LNC-2000,SJM Line Lock. 747 whp 714wtq
Build thread http://www.camaro5.com/forums/showth...55#post8107855 |
12-03-2015, 06:51 AM | #6 |
Drives: 2011 SGM 1SS/RS M6 Join Date: Feb 2012
Plus if your car is a 2011 as your profile says...warranty is just about done anyways, so just enjoy. Unless you feel like you really need that warranty,than I wouldn't bother.
Mine is also a 2011 and I just had it tuned...I figure I was going to put maybe 3-4k miles on it between now and then end of the warranty. Dealer didn't say anything when I had it in for a state inspection...they Def won't check while putting tires on. If you are that concerned bring it somewhere else for tires, will prob be cheaper anyways.
Current: 2011 SGM Camaro 1SS/RS M6 - CAI Cold Air Kit, Janetty Tuned
12-03-2015, 09:13 AM | #7 |
Drives: 2006 Z06 Join Date: Oct 2010
Why goto dealer for tires anyways?
Nick
Corvette Z06 -1200ish rwhp |
12-03-2015, 09:37 AM | #8 |
Agreed, many better places to get tires cheaper!
Black GFX / Dynatech Supermaxx LT Headers / FR Black Chrome ZL1 Replicas 275/315 / RDP Tune / CAI / VMAX TB / MBRP SS Catback / Gtechniq CSL & EXOV3 / VTC / RX Catch Can / Valentine 1 / Halo DRL / LED Fogs
12-03-2015, 09:42 AM | #9 |
Drives: 2000 Camaro SS Join Date: Feb 2010
There is no point. If they want to dig they can look at your flash log and see what you did. You can't hide tuning on these cars.
12-03-2015, 10:18 AM | #10 |
12-03-2015, 10:19 AM | #11 | |
12-03-2015, 10:21 AM | #12 |
Thanks man! Is there a reason other than warranty that I should return the car to stock when taking it in for work? Only reason I'm asking is because the guidebook that came with my tuner recommends that I return to stock before taking it to the dealer.
12-03-2015, 10:22 AM | #13 |
12-03-2015, 10:23 AM | #14 | |
dealer, high flow cats, long tube headers, tuned |
