Old 03-07-2024, 12:51 PM   #1
zx9rmal
zx9rmal's Avatar
Drives: '20 ZL1 M6
Oil filter confusion
I couldn't get the search page to load. I got an AC Delco PF64 oil filter from Amazon. On the filter is #12706595. When I did a look up for AC Delco, the
PF 64 # is 19386865. What gives?
Mal
Ft. Lauderdale, FL
'20 Camaro ZL1 M6
'22 Kawasaki ZX-14R
zx9rmal is offline   Reply With Quote
Old 03-07-2024, 12:57 PM   #2
cdb95z28
cdb95z28's Avatar
Drives: 2022 1SS 1LE A10 BCD WCT+PDR
There's been updates to the PF64. As long as it says PF64 it's good. The PF64 I have is 25206377!
No worries, send it!
cdb95z28 is offline   Reply With Quote
Old 03-07-2024, 01:44 PM   #3
arpad_m
arpad_m's Avatar
Drives: 2018 Camaro 2SS A8
GM changes the PF64 filter more frequently than one changes their underwear. I am aware of at least two "update streams", see below, the final SKUs of which (25206377, 19419226) are both marked as available:
12640445 -> 12696048 -> 12706595 -> 25206377
19386865 -> 19419226
No idea what the differences among them, if any, are, I suspect supplier changes and the use of ever cheaper materials.
I loved the original 12640445 filter, by the way, it was sturdier, thicker and looked more robust.
Last oil change I used an Amsoil filter (EA15K50) along with their oil. Yes, I know it's 3x more expensive than these ACDelco filters, but boy, does it look and feel way more solid, and at $5 vs $15, nobody cares about the higher price (let the flame war begin ).
735 rwhp | 665 rwtq
3000 - 2/06/18 TPW 2/26/18
Old 03-07-2024, 02:14 PM   #4
CalgaryZL1
CalgaryZL1's Avatar
Drives: 2020 Chevy Camaro ZL1
As long as you have close to a 22 psi bypass rating for the filter any quality brand will be ok.
CalgaryZL1 is offline   Reply With Quote
Old 03-07-2024, 02:22 PM   #5
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
This.
I am doing something similar. I started (last oil change) using their oil and filters in their service kit (for lack of a better term), instead of the Mobil oil and Delco filter I was using.
'20 ZL1 Black "Fury"
radz28 is online now   Reply With Quote
Old 03-07-2024, 02:26 PM   #6
zx9rmal
zx9rmal's Avatar
Drives: '20 ZL1 M6
Thanks guys. This is crazy. Isn't there also a "longer" version of the PF64. UPF64R??
Mal
Ft. Lauderdale, FL
'20 Camaro ZL1 M6
'22 Kawasaki ZX-14R
Old 03-07-2024, 02:29 PM   #7
zx9rmal
zx9rmal's Avatar
Drives: '20 ZL1 M6
On another note, I'm having myM6 fluid changed today. What is the reason for the level to be 1/8 below rather than at the bottom of the fill hole?
Mal
Ft. Lauderdale, FL
'20 Camaro ZL1 M6
'22 Kawasaki ZX-14R
Old 03-07-2024, 02:30 PM   #8
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
Drives: Red Hot A10 ZL1 Convertible
More is not always better
Yeah but you certainly don't want a UPF64R (35psi bypass) and probably also don't want to dangle any precious bit of engine kit down below the pan where the speedbumps et al will remove the end of it in an unscheduled and violent fashion.
Gunkk is offline   Reply With Quote
Old 03-07-2024, 04:03 PM   #9
Fenmore
Drives: 2017 Camaro ZL1
Which Amsoil oil did you go with? I was gonna switch on my next change as well.
Fenmore is offline   Reply With Quote
Old 03-07-2024, 09:22 PM   #10
arpad_m
arpad_m's Avatar
I use Amsoil Signature 10W-30 with my mods (see them below).
735 rwhp | 665 rwtq
Old 03-08-2024, 09:31 PM   #11
discgolf01
Drives: 2018 ZL1 Convertible M6
This might help, this is the official GM communication:
https://gmserviceinsights.com/new-ac...d-performance/
discgolf01 is offline   Reply With Quote
Old 03-08-2024, 10:09 PM   #12
JSH
JSH's Avatar
Drives: '20 ZLE
https://drivenracingoil.com/c-138947...l-filters.html
LME uses Driven filters here
'20 ZL1 1LE A10,
OEM short block, LME heads/valve train, E2650.
100+ octanes, no eth, no meth, no N2O.
2/23 - 1031/1004 wheel.
4/23 - 1.41/9.61/145 at DA 7000 ft. (only made five passes).
2/24 - LME 390, E2650, FBO, 100 oct.; 1116hp/ 1063tq; 109 oct. dyno next.
JSH is offline   Reply With Quote
Old 03-09-2024, 10:07 AM   #13
getchapull
TEXIT
getchapull's Avatar
Drives: 2019 ZL1 M6
The Wix WL10290XP oil filter is well made and has the correct bypass (22) PSI for the LT4 engine.
Added bonus: it's painted black to match my car!
getchapull is offline   Reply With Quote
