Old 02-19-2020, 01:22 PM   #1
Katech_Zach
Katech_Zach's Avatar
Drives: 14 Camaro SS 1LE
Katech ZL1 Stage 4, Serial 010
Just received this beautiful Bright Yellow Camaro ZL1 at the shop. It will be getting our Stage 4 package for the automatic transmission. Haven't seen a whole lot of this color, I must say it looks very good in person.
I wanted to share the whole process with the forum from start to finish on one of our most popular packages that we sell. We have tons of Stage 4 LT4 builds floating around in the Corvette world, we all know that Camaros have the potential to be on top
All of our valvetrain packages are spintron validated with a 1000 RPM factor of safety, you will never have to worry about dropping a valve or having any sort of valvetrain instability.
Our Stage 4 includes:
-Katech Billet Valley Cover, AFM Delete
-ARP Head Studs
-New LT4 Head Gaskets
-Katech K-Force 2 Camshaft
-Tool Steel VVT Lockout
-OEM GM Cam Bolt
-PSI 1511 Valve Springs
-Katech CNC Ported Heads
-Katech CNC Ported Chambers
-Katech Competition Valve Job
-Katech Hand Blend Valve Job to Chambers/Port
-Katech Tool Steel Intake Retainers
-Katech Tool Steel Exhaust Retainers
-Katech Tool Steel Spring Seats
-Trend 3/8 0.080 Hardened Steel Pushrods
-OEM Crank Bolt
-New LS7 Lifters
-New GM Lifter Trays
-Katech C5.R Timing Chain
-Katech Blue Viton Valve Seals
-Katech Spark Plug Wire Insulators
-Brisk Racing Spark Plugs
-Rotofab Big-Gulp Intake
-Katech 103mm Throttlebody
-Griptec Supercharger Upper Pulley
-Griptec Supercharger Upper Hub
-ATI Damper, LT4
-ATI Damper, 14% Overdrive
-Gates Heavy Duty Serpantine Belt
-New OEM Cradle Bolts
-New Coolant (GM Dexcool)
-New Oil (Mobil1 0w-40)
-New OEM Filter
-AP600 Brake Fluid
-New GM Flywheel Bolts
-Baseline Dyno
-Street Calibration
-Chassis Dyno Calibration
-Katech Serialized Plaque with our 3 year, 36,000 mile warranty.
Stay tuned for more, cheers.
Katech_Zach is offline   Reply With Quote
Old 02-19-2020, 01:48 PM   #2
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
I’m tuned in Zach!!
LT4Greg is offline   Reply With Quote
Old 02-19-2020, 02:37 PM   #3
IneedAZ
IneedAZ's Avatar
Drives: 2017 ZL1 A10 & 2021 BMW M340i x Dr
What fuel lobe on the cam? 38% ?
Sold 2012 2LT RS 12.3@112 old setup
Sold 1967 Camaro Pro Street. Ran 10's mild BB on NOS.
2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17
2020 Build: Mag2650, BTR Stage2, NW103, BG, 14% lower, 90mm upper, ARH 2" Long system w/no cats, SW Legend mufflers. **807hp/762tq on 93 gas** and **848hp/792tq on e47**
Sold 2018 (Go Mango) Dodge Charger Daytona 392 Daily Driver
Daily Driver 2021 BMW M340i Xdrive
IneedAZ is offline   Reply With Quote
Old 02-19-2020, 03:10 PM   #4
Katech_Zach
Originally Posted by LT4Greg View Post
I’m tuned in Zach!!
Engine is almost out!
38% Fuel Lobe, also want to note that this is our everyday street camshaft, it maintains the factory powerband and driving characteristics. Very good all around with no compromises.
Old 02-20-2020, 08:41 AM   #5
JonDaddy82
JonDaddy82's Avatar
Drives: 2018 ZL1 Coupe NFG M6
No ported blower on the list?
1989 Forumla 350 WS6 <- High School
2000 Trans Am Firehawk <- After High School
2017 Colorado Z71 <- Daily
2018 ZL1 M6 <- Not Daily
JonDaddy82 is offline   Reply With Quote
Old 02-20-2020, 08:50 AM   #6
harner
harner's Avatar
Drives: 2018 ZL1 A10
I was wondering the same thing.
SOLD! 9/1/2020 2018 ZL1 A10 Hyper Blue - Rotofab CAI, Gibson catback
@SurefireDetail
OEM ZLE tails/third brake light, Gen5DIY reverse LEDs, front Amber LEDs, SMG laser LED side markers, SMG smoked reflectors
1994 Trans Am LM7/CPT 4L60E/9"
1987 IROC
2006 Silverado
harner is offline   Reply With Quote
Old 02-20-2020, 09:07 AM   #7
FoundNemo
Drives: 2019 ZL1
In to follow!
Katech_Zach do you have any dynos of your Magnuson 2300 swap only package (the one that is 8kish for a 2019+ A10 ZL1). You list 750hp but curious what those put down SAE, figured 650ish whp / 650tq.
FoundNemo is offline   Reply With Quote
Old 02-20-2020, 09:42 AM   #8
JackZL1
Drives: 2019 Zl1 Camaro.
Can't wait! Beautiful color as well.
JackZL1 is offline   Reply With Quote
Old 02-20-2020, 09:45 AM   #9
Exgermanowner
Drives: Bone stock
How about anything to deal with the additional heat?
2018 ZL1 - Garnet Red, NO Sunroof, A10, PDR, Carbon hood insert = Perfect
Exgermanowner is offline   Reply With Quote
Old 02-20-2020, 11:19 AM   #10
PROMETHEUS
PROMETHEUS's Avatar
Drives: 2019 ZL-1, Shadow Gray, Sold
Yep, didn't see any cooling upgrades, either!
PROMETHEUS is offline   Reply With Quote
Old 02-20-2020, 11:49 AM   #11
Katech_Zach
No additional cooling upgrades at the moment, it is 100% a street car. We also do not overspin the blower, so IAT's and head temps stay relatively cool.
Old 02-20-2020, 12:29 PM   #12
Katech_Zach
Engine is out and off to the engine-build que. Spring is busy so the line will be quite long, but worth it once this beast is put back together. Stay tuned.
Old 02-20-2020, 10:44 PM   #13
waterman
waterman's Avatar
Drives: Grandad's C2 L89
2018 ZL1 1LE sw/PDR
waterman is offline   Reply With Quote
Old 02-22-2020, 12:56 PM   #14
that_zl1_1le
Drives: Chevy zl1 1le
that_zl1_1le is offline   Reply With Quote
