04-13-2017, 04:32 PM | #1 |
Drives: 2017 Camaro SS 1LE Join Date: Mar 2017
Front brake rotor replacement
Hey everyone first post here after having the car for about 2 months and so far it has not disappointed at all after 2 track days and daily driving. One thing I've wondered a bit is when it comes time to replace the front rotors, as they are 2 piece I would have thought that you could just buy the rotor rings, GM only seems to offer the complete rotor and hat assembly. Has anyone else seen just the ring or are we doomed to buying the complete assembly every time?
04-13-2017, 04:43 PM | #2 | |
Drives: '19 RivrsdBlu 1LE ('17 1LE HB sold) Join Date: Nov 2016
I have been also doing my research on this and had a chance to speak with a couple makers and will keep everyone update on this
04-13-2017, 04:45 PM | #3 |
oh another option is the slotted rotors but I remember reading they weigh the same with the OEM blank 2 pieces so it doesn't seem like a good option to justify the price tag on each rotor ($250 vs $500!!)
The similar drilled rotors for the C7 Z06 only costs about $250-300 not sure why ours are that expensive but unlike the Corvettes ours are rotational which is very good
04-13-2017, 05:46 PM | #4 |
Definitely interested in any aftermarket options you may find. How are you liking the Raybestos ST43s? Do you run them daily as well and how do they handle that?
04-13-2017, 06:35 PM | #5 |
Drives: 2023 CT5 Blackwing Join Date: Sep 2016
OEM rotors (Front) MSRP for $674.
Part# 23142500 (R) 23189768 (L) GMpartsdirect.com has them for $377.
2017 HBM SS 1LE
Sold 2023 Wave Metallic CT5-V Blackwing M6 |
05-16-2018, 10:20 AM | #6 |
Daily Driven 1LE
Drives: 2018 1SS 1LE Join Date: May 2018
Has anyone found a cheaper source for 1LE SS rotors?
05-16-2018, 10:29 AM | #7 |
Drives: 17 SW 1LE Join Date: Jun 2017
DBA makes rings, you can get them from KNSbrakes or PFYC. If you search this subforum for DBA or rotor rings you will find the thread with part numbers.
05-16-2018, 05:03 PM | #8 |
Drives: 17' 1SS 1LE GBA-Black Join Date: Mar 2017
05-16-2018, 06:45 PM | #9 |
Oops. Thanks for catching that!
2017 HBM SS 1LE
05-16-2018, 09:30 PM | #10 |
Big Samoan ina little car
Drives: 2016 camaro Join Date: May 2014
Just a hint.. if you plug in the ac delco equivalent numbers of the gm 1LE 6 piston rotors, and use the 5% coupon at rock auto... 335 shipped. Just sayin.
Don't sit around and watch everyone else live YOUR dreams...DO SUMPT'N
When I see posts asking "whats the best intake, exhaust, etc" .... the answer to that is like a grandfather telling his grandkids "if you put salt on a birds tail, it'll let you catch it" #ThinkAboutIt "Winning Tip: Don't take my (or anyone else's) word for it. GO TEST IT!" - Dennis Grant |
05-17-2018, 08:14 AM | #11 |
Drives: 2017 Camaro 1LE SS Join Date: Oct 2016
DBA rotors work great. And they're cheaper.
05-17-2018, 05:34 PM | #12 |
08-12-2018, 05:19 PM | #13 |
1LE Convert
Drives: 2018 ZLE Join Date: Apr 2017
Anyone know if the caliper mounting bolts need to be replaced when doing a rotor job? What part number would they be and torque spec?
08-12-2018, 08:11 PM | #14 |
Drives: 2017 C7 GS M7 / 2017 Camaro SS 1LE Join Date: Dec 2016
By the way guys does 1LE SS and GrandSport brakes have the same brakes, rotor appart (which are slotted on the GS)
They look pretty close for what I see, same size and 6 pots both.... I have a set of pads from the GS I don't use since I run Carbotech racing pads on the vette...... Thx |
Thread Tools | |
