03-16-2022, 06:45 AM | #1 |
Drives: 2018 Chevy Camaro 1ss Join Date: Nov 2020
Texas speed drop in combo?
Anybody using Texas speed /JE piston drop in combo? Looks like the only thing readily available for drop-ins.
03-16-2022, 09:01 AM | #2 | |
I already have those so I didn't bother to check. That being said, if the Texas Speed combo is available, and competitively priced, there's no reason not to go with them.
Baby Blue
03-16-2022, 09:44 AM | #3 |
GPI is backordered.
TSP in stock. Vengeance racing doesn't specify. If you plan on running 93 get the 10.5:1 compression pistons. If you are going to run E then stock compression is fine but I believe only GPI offers that. Most other drop in kits lower compression. Contact TSP to verify...not sure why it's not mentioned.
2016 NFG 1SS A8
03-16-2022, 10:48 AM | #4 |
Texas speed says -6 piston. They do offer a Carrillo piston/rod combo that drops it to 10.5. definitely running e-85. Doing JRE cam set up while it's out,just making sure I get correct piston/rod combo
03-16-2022, 10:55 AM | #5 |
Old badass
Drives: 14GMC 2.9 16GMC Turbos 2020Silv.6.2 Join Date: Mar 2020
+1 for King's comment. Talked to GPI on Monday they said rods are in fact backordered and no clue when they will show. I don't like the rods from TSP as they don't show to be rated high enough for me. Waiting it out.
I've had 7 Camaro's. All gone...for now.
Current build in progress 2016 GMC4x4 RCSB twin hair dryers ~1k whp fbe port inj 1/8 mi & stealth street terror |
03-16-2022, 11:55 AM | #6 |
Drives: 2016 Camaro 2SS Join Date: Apr 2018
The rods from TSP are pretty similar to the GPI versions so I wouldn't hesitate to run them. Now if you're shooting for 1000 or close to it I'd just do a custom setup and pick a stronger rod than both of those listed.
03-16-2022, 12:50 PM | #7 |
Any recommendations for a engine builder in Michigan? Called a couple places and they want to use all their own parts before they will put their name on it,I could put it together myself but would feel better having someone assemble it for me and I will just reinstall the motor myself.
03-16-2022, 03:13 PM | #8 | |
Former GM Technician
Drives: 2018 ZL1 A10, 06 Silverado Duramax Join Date: Sep 2009
https://www.strictlyperformance.parts/
2018 Camaro ZL1 A10
Rotofab Big Gulp, Nick Williams 103, Magnuson 2650, 9.17" (14%) lower, 90mm upper, Vengeance Racing Heads (LME) Cam Package (Cammotion Stage 1), Johnson Lifters, JMS Voltage Booster, Lingenfelter high flow check valve, BBK shorty headers, Custom 2.75" down pipes, Gesi Gen2 high flow cats, MM catch can 791whp, 772ft-lbs SAE Just added 30% XDI Injectors, LPE big bore hpfp, Flex fuel. Elite tuning, results coming soon. 2006 Silverado Duramax Diesel MPI Compound Turbo 40% over Injectors Efi Live DSP5 Tuning Follow me on Instagram: Swisstyphoon1980 |
03-16-2022, 03:16 PM | #9 | |
03-16-2022, 03:25 PM | #10 |
Damn, I would try to reach them again..
They have a pretty cool engine build video on youtube. https://youtu.be/EBYc0I4Qq5U
2018 Camaro ZL1 A10
03-16-2022, 03:54 PM | #11 | |
03-16-2022, 11:07 PM | #12 |
Old badass
Yeah I was just going by what LME and Strictly list those rods as good for in their LT builds 11-1200 whp. I didn't think TSP's were that stout. If they are then hell yeah
03-16-2022, 11:30 PM | #13 |
Yeah they all have different opinions on them. If I remember correctly GPI were comfortable with the compstars up to 900-1000.
03-17-2022, 10:34 AM | #14 |
Old badass
Good info much appreciated.
