01-14-2023, 09:17 AM | #1 |
Convert Kooks Header to V-band Clamps?
Hello.
I was curious if anyone has converted their headers from the garbage ball and socket joints at the header collector to V-band style clamps? I have Kooks headers and I keep getting an intermittent P105B code from an exhaust leak. I suspect it is the ball and socket connection. Kooks now uses a rounded band clamp that I don't think seals very well. I do use the high temp exhaust gasket sealant from Permatex but I keep getting the code. Kooks used to use a clamp that was a flange on the header and a flange on the connector pipe that pulled the tow pieces together and you could really tighten up on it. The new style just sucks. I am going to change out my header flange gaskets just in case but I doubt it will help. Was thinking that changing over to a V-band could solve this. Only problem is finding an exhaust shop that knows what the hell they are doing. |
01-14-2023, 10:52 AM | #2 | |
I knew tons of shops in Detroit, not many down here though |
01-14-2023, 11:11 AM | #3 |
Drives: '86 IROC-Z '18 ZL1 Join Date: Jul 2019
If I wasn't in a rush to put the exhaust on, I'd prob went v clamps. But the regular clamps worked for me after I got them adjusted.
01-17-2023, 06:36 AM | #4 |
So update. I figured I might as well try to tighten up my exhaust manifold to head bolts and see if maybe that would fix my issue. None of the bolts were loose but they did turn a bit as I tightened them to 20 lb-ft. And that seems to have fixed the problem.
So fingers crossed for now. |
01-17-2023, 08:59 AM | #5 | |
Drives: '16 2SS M6 Join Date: Aug 2019
David
'16 2SS M6 black on black, SW long tube full exhaust, NPP, Roto-fab CAI, ported stock TB '16 2SS M6 black w/Metallic black stripes, Kalahari, 6 piston front (totaled 1/22/20) '14 Fusion Titanium 2.0T '83 Jeep Wagoneer |
01-17-2023, 09:59 AM | #6 |
Having FUN in the SUN...
I upgraded my ARH flanges to V bands, and wish i would have done this before i powder coated them. The seal is so much better, with no leaks.
01-17-2023, 11:35 AM | #7 |
Drives: 17 camaro ss Join Date: Mar 2018
If you can, try taking them off and just taking the headers to the shop so they don't have to worry about emissions stuff
01-17-2023, 11:49 AM | #8 |
Drives: 1999 Camaro SS M6 - SBE LS1 Join Date: Jun 2018
This might not apply to the OP, but after installing headers, it's advisable to at least re-torque your header bolts after 1 or 2 heat cycles.
Note, the temp at which you torque plays an important aspect in this as well. Torqueing warm or hot, is actually much higher torque than cold.
1999 Camaro SS 6M - SBE LS1
1963 Corvette GrandSport - ZZ502 4M 2017 Denali 1500 6.2 2017 Yukon Denali 6.2 |
01-17-2023, 11:52 AM | #9 | |
Shadow Gray '19 ZLE M6
01-17-2023, 04:03 PM | #10 |
Lots don't realize this and then wonder why it's so hard to remove certain bolts/nuts that were torqued hot.
01-18-2023, 09:11 AM | #11 |
BAMF SS
the ball and socket flange works very well, when used properly. don't forget that you have to torque the clamp..... excessively tightening it will cause a leak.
have you tried replacing the oxygen sensor?
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock 800 SAE rwhp. 9.4 @ 145 mph. |
01-19-2023, 07:11 AM | #12 |
Drives: 2022 Camaro LT1 Join Date: Nov 2022
01-23-2023, 07:08 PM | #13 |
