TireRack
Old 02-25-2013, 10:27 AM   #1
Fentito5thgen
Sombra
Fentito5thgen's Avatar
Drives: 2019 Satin Steel Gray 2SS
LED tail light bulb, HELP !!!
Hi everyone,
I just picked up a set of 3157 LED tail light for my 2LT/RS 2013 and they look nice. The problem I have now is that they will come on just fine, but when I put the turn signals after a few seconds I get a DIC warning stating to check my turn signal bulbs, and they begin to blink faster. Now, I have check them for connection and to see if they are out, but they are working properly, the only thing is the DIC warning and the faster than normal blinking. Am I missing anything? I appreciate any help from Camaro5 experts.
Thank you again.
I attached few pics of the LEDs for everyone to see.
"Hey, you want to lay the fate of the world on the kid's Camaro? That's cool." Agent Simmons (S7) TF 1
Fentito5thgen is offline   Reply With Quote
Old 02-25-2013, 10:38 AM   #2
ackeight
ackeight's Avatar
Drives: 10' 2SS/RS
My grand am did that too. They use much less power than the normal bulbs and the car thinks they are not working. That is why they blink fast. You need some sort of resistor or something like that in line with the bulb to use some more power to use the LEDs. I may be using the wrong terms but that's the gist.
ADM tuned 412HP/407RWTQ. Kooks 2" headers w/ cats, ADM race intake, Vmax TB, Pedders XA coilovers and ZL1 sways. 1le clone
ackeight is offline   Reply With Quote
Old 02-25-2013, 11:02 AM   #3
MR.Sarge
MR.Sarge's Avatar
Drives: 2015 2SS/RS 1LE
Yup you need a load resistor to take care of that hyper-flashing, pretty sure this will do the trick, maybe someone can verify this:
http://www.gen5diy.com/Lighting/Load_resisters
MR.Sarge is offline   Reply With Quote
Old 02-25-2013, 01:32 PM   #4
gutterball
gutterball's Avatar
Drives: 2014 1LS M6 Supercharged
Send a message via AIM to gutterball
You need a Resistor, 6 - 8 ohms, from the Pos lead to Gnd (Grn or Ylw wire, depending wether it's the left lamp or right lamp). Resistors should be attached to chassis (as they will get hot) and be at least 35 watts.
gutterball is offline   Reply With Quote
Old 02-25-2013, 01:34 PM   #5
Fentito5thgen
Sombra
Thanks for the rapid response, also do you think leaving the LEDs in for now will damage something, until I get these (resisters) ordered?
Thanks again
Old 02-25-2013, 01:48 PM   #6
ackeight
ackeight's Avatar
Drives: 10' 2SS/RS
It shouldn't damage anything. I left mine on for tens of thousands of miles.
Old 02-25-2013, 06:49 PM   #7
MR.Sarge
MR.Sarge's Avatar
Thanks again
You're fine going as you are now without the resistors. Only thing is you'll always have hyper-flashing until you install the resistors to eliminate it and normalize the flash rate.
Old 01-20-2016, 12:43 AM   #8
BigRed82
Drives: 2015 2LT RS Camaro
Sorry to bump an old thread, but which ohm resistor do I need for license plate LED's to stop them from blinking/flashing?
BigRed82 is offline   Reply With Quote
Old 01-20-2016, 12:58 AM   #9
MoCamaro10
Drives: 2010 Inferno Orange Camaro
You don't need a resistor for the plate led's. If they are flashing/blinking, just make sure you have them fully seated in the plug.
MoCamaro10 is offline   Reply With Quote
Old 01-20-2016, 12:59 AM   #10
BigRed82
I did, they're definitely fully seated and they still flash. Under the description of the resistors on the gen5diy site it says the resistors are for the license plate lights as well.
Old 01-21-2016, 02:09 AM   #11
MoCamaro10
My bad. It might be different for the newer models. I have a 2010 and I was able to just swap in some t10's with no problem.
Old 01-21-2016, 02:17 AM   #12
ghosted
BCS Auto
ghosted's Avatar
Drives: 2015 Camaro 1LS
2015 LS here, no blinking in my License Plate LEDs.
BCS Auto on Facebook - - - Follow me on Instagram @datv6tho & @officialbcsauto
ghosted is offline   Reply With Quote
Old 01-21-2016, 11:57 AM   #13
BigRed82
Where did you purchase yours from? I know the Phillips type come with a resistor installed but they're about $10-each.
Old 01-21-2016, 12:39 PM   #14
DonM
Camaro #4
DonM's Avatar
Drives: 2017-Hyper Blue Metallic-2LTmanual
How much brighter are the LED tail light bulbs than the standard ones in a 2013 LS?
Don M
Supercharged LGX + 6 speed manual = FUN!!
DonM is offline   Reply With Quote
