10-05-2023, 07:16 AM | #1 |
Drives: 2010 Camaro SS Join Date: Mar 2022
Unable to find power steering hose - HELP!
Hello,
Currently sprung a hell of a leak on the power steering lines and I’m unable to find one dry rotted hose leaving me in the dust here. Does anyone have access to a part# 92249335 or equivalent. Thank you! |
10-05-2023, 09:31 AM | #2 |
Few Options.
You might find a local hose shop that can make you a serviceable replacement, but probably won't be the exact same. Since this is the low pressure side, you might be able to cut the metal lines and find a compression style coupling to swap it to AN/fittings. Several of us have done that on the transmission cooler lines. Although it shows discontinued, a dealer might be able to find it as NOS on someone's shelf. Junk yard |
10-05-2023, 12:55 PM | #3 |
Drives: 2010 Camaro 2ss/rs, 2008 Avalanche Join Date: Jan 2019
If it's the low pressure side you can cut the metal line and put a slight flair on it ,clean the rough edges ,and use some rubber fuel hose . Slip the hose over the flaired end and hose clamp. I've done this many times and never had a problem. Don't flair it like normal flair ,maby half that ,it's just added security that it doesn't come off !
Ps. You could even use steel braided fuel hose for added security!
10-05-2023, 02:09 PM | #4 |
Drives: 2012 SS Join Date: Dec 2021
2012 Camaro SS
10-05-2023, 05:21 PM | #5 | |
Drives: 2013 ZL1 Join Date: Nov 2015
10-07-2023, 06:53 AM | #6 | |
They don’t seem to be too interested. |
