12-24-2014, 01:50 PM | #1 |
Drives: 2014 2LT RS Join Date: Jan 2014
When turning on the Heater
When I turn on the heater, The Snow flake turns on automatically. Any way to disable it?
arrow next to the "Snow Flake" |
12-24-2014, 01:55 PM | #2 |
Drives: 2011 1LT Join Date: Mar 2012
That's probably a malfunction.
To MY knowledge: The snowflake indicates that the AC compressor is activated, and should only be on if you have activated the AC, or if you have the defroster on (the AC compressor takes moisture out of the air, thus helping to dry the windshield faster than just circulating "undried" air over the surface). On mine, the snowflake is not illuminated when I have just the heater on... |
12-24-2014, 02:01 PM | #3 |
When I initially turn on, the "snow flake" turns on automatically.
I always have to press on the "snow flake" to turn it off. |
12-24-2014, 02:05 PM | #4 |
Dazed &
Drives: matte blue 2014 z28(186) 2015 R1 Join Date: Jun 2013
I do as well.. maybe its not a malfunction? I'm curios to see what other people say.
12-24-2014, 02:09 PM | #5 |
Drives: 2018 Camaro 1LT Hyper Blue Metallic Join Date: Nov 2013
Your car is just obsessed with 'Frozen'.
12-24-2014, 02:11 PM | #6 |
Drives: 2017 2SS, 2000 Trans Am Firehawk Join Date: Jun 2014
It's normal. A/C removes moisture from the air so the car windows do not fog up. Cars have been this way for many years.
12-24-2014, 02:13 PM | #7 | |
Captain Gingerbeard
Drives: 2012 IOM RS/SS 6MT Join Date: Feb 2013
What this guy said. The car is assuming you don't want frozen window from the inside syndrome.
Custom ordered 2012 6MT RS/SS on 11/25/2011. Picked up 01/31/12.
Pedders Coilovers, BMR trailing arms and toe-links, Prothane solid poly subframe bushings, JDP Motorsports rear upper control arm bushings, Texas Speed long-tube headers with 2" primaries, modified fully 3" Magnaflow competition catback. CAI cold-air intake. DBA rotors, Hawk pads. Quote:
12-24-2014, 04:59 PM | #8 |
Yup, A/C is actually a great method to prevent fogging.
Modifications
GM Dark Tail Lights / 3rd Brake Light & Reflectors | LED Reverse Lights | Diode Dynamics Side Markers | Borla "ATAK" Cat Back Exhaust |
12-24-2014, 06:50 PM | #9 |
Scott's45
Drives: 2012 2SS 45th Anniversary Join Date: Mar 2012
That looks like your a/c is on to me. I've never used the heat before, but i have used the vents in the mode you have lit up on the left. Press the snowflake again and it should go off. The a/c usually only kicks in when you use the defroster, not using the vents on the dash and floor.
2012 2SS 45th Anniversary, Hurst short throw shifter, Stainless Power LT headers, high flow cats, SW Retro Chambered 3" cat back, CAI, Heritage grill, tinted windows, red/silver hash stripes, AAC LED sidemarkers, blacked out turn signals/tail lights, splash guards. 402RWHP
12-24-2014, 09:23 PM | #10 |
Once you push the snowflake button to turn off the compressor it should not continue to turn on by itself. You have a problem if it turns on , mine does not do that.
12-24-2014, 09:55 PM | #11 |
Drives: 2019 Dodge Challenger Scat Pack Join Date: Apr 2014
Wait. The AC activates when I turn on the window heater? I've never noticed this
12-24-2014, 10:47 PM | #12 |
Welcome to the Features of a 2014+
Modifications
12-24-2014, 11:15 PM | #13 |
That's funny I had the same thing happen the other day. Except when I use the A/C in the summer and get back in the car after awhile the A/C is turned off. Who knows lol.
12-25-2014, 01:45 AM | #14 |
Drives: 2016 2SS, 2008 HHR ECTO-2H Join Date: Aug 2009
Yep mine always comes on when I turn the heat on. But if I shut the car off with the heat on when I come back later it remembers I turned the AC off.
2016 Camaro 2SS. Hyper Blue, Ceramic White, Auto, MRC, and NPP.
1100 - 9/25 2000 - 9/28 3000 - 9/30 3100 - 10/27 3300 - 10/28 3400 - 10/29 TPW 11/09 3800 - 11/10 4300 - 11/24 4B00 - 11/25 4200 - 12/5 5000 - 12/7 6000 - 12/11 |
