Old 10-18-2018, 03:13 PM   #1
590_The_Judge
590_The_Judge's Avatar
Drives: 2018 ZL1 1LE NGM
ZL1 1LE hood wrap
Hello all, my car has 1984 miles on it after 7 months, and as i got into the car today i noticed the hood wrap appears to be pulling up and peeling itself off. I only took pics on one side, but it is happening on both sides.
Anyone else notice this at the corners next to the carbon insert?
Thanks!
590_The_Judge is offline   Reply With Quote
Old 10-18-2018, 03:18 PM   #2
Joszer
Use a blow dryer to heat up the area and iron it down with your finger. Should seal it back up well.
Joszer is offline   Reply With Quote
Old 10-19-2018, 03:18 AM   #3
URBAN LEGEND
URBAN LEGEND's Avatar
Drives: 20 X3M CP & 19 ZL1 1LE A10
Awaiting the usual garbage answer of “take it to the dealer.”
🔺22 RS E TRON GT
🔺21 Model S Plaid
URBAN LEGEND is offline   Reply With Quote
Old 10-19-2018, 08:24 AM   #4
NW-99SS
Drives: 1999 Camaro SS M6 - SBE LS1
X2
1999 Camaro SS 6M - SBE LS1
1963 Corvette GrandSport - ZZ502 4M
2017 Denali 1500 6.2
2017 Yukon Denali 6.2
NW-99SS is offline   Reply With Quote
Old 10-19-2018, 08:50 AM   #5
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
Drives: 16 SS & 17 ZL1 Both Yellow
Send a message via Skype™ to EDFHOBBIES
If the adhesive is still good on the wrap you might 3m edge sealer in a pen or Rtape which is extremely thin dbl sided tape.
Kong Ported 2650, Crawford Racing Port Injection, Weapon X 112mm Adapter, NW112mm TB, Livernois Ported LT4 Heads, Lingenfelter GT32 stealth cam, Haltech Elite, and Carbon by Trufiber
EDFHOBBIES is offline   Reply With Quote
Old 10-19-2018, 10:06 AM   #6
ZZebes
My wrap was very poorly done, Ended up having a local wrap company replace it.
2018 ZL1 1LE
ZZebes is offline   Reply With Quote
Old 10-19-2018, 10:19 AM   #7
coruiz
Drives: 2018 Camaro 2SS Hyper Blue
take it to the dealer :belly roll:
2018 Camaro 2SS
| Hyper Blue Metallic | A8 | NPP | MRC | NAV | HUD | ATAK |
coruiz is offline   Reply With Quote
Old 10-19-2018, 11:22 AM   #8
Tim202
Jeez, I haven't even looked close in that area. Now I'm scared to.
Tim202 is offline   Reply With Quote
Old 10-19-2018, 12:33 PM   #9
URBAN LEGEND
My man!
🔺22 RS E TRON GT
🔺21 Model S Plaid
Old 10-19-2018, 12:46 PM   #10
ICTsccaCamaro
ITCRNRS
ICTsccaCamaro's Avatar
Why would you not take it to the dealer this would be covered under the 3 year 36000 mile basic warranty, my car is doing the exact same thing and I will have it redone at the end of the basic warranty for free through the dealer, my 2014 1LE also had a small area that was pulling up and I waited until the last months of the 3 year basic warranty to have it replaced for free
2018 ZL1 1LE Ordered 6/29/17 Built 11/6/17 Delivered 12/7/17, Summit White, PDR, NAV, https://www.youtube.com/c/tylerpotter
SOLD: 2014 Summit White 1LE 2SS/RS, Recaros, NPP, NAV, KONI Yellow's SOLD: 2012 Black 2LT/RS, Fully 1LE swapped, Brembo swap
ICTsccaCamaro is offline   Reply With Quote
Old 10-19-2018, 12:50 PM   #11
ICTsccaCamaro
ITCRNRS
That's what a factory warranty is for correct? If your motor or trans blew up i'm assuming you wouldn't take it to the dealer either?
Old 10-19-2018, 12:53 PM   #12
ICTsccaCamaro
ITCRNRS
Vs. having it redone for free under factory warranty seems like a waste of money?
Old 10-19-2018, 02:05 PM   #13
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
They do use a better wrap on the 2019's. Hopefully this will be a non-issue going forward.
Old 10-19-2018, 04:37 PM   #14
590_The_Judge
That you all for the responses. It is still tacky on the backside, i applied pressure rolling it back... no luck. Im going to keep an eye on it and will take it to the dealer under warranty before the three year warranty expires. The post was party a heads up... i saw it, wanted to make sure those more skilled than me could potentially keep theirs in good shape should it happen to other cars.
