04-17-2021, 06:22 AM | #1 |
Drives: 2014 1LE Join Date: Apr 2019
New cam on my 1LE
I just got a new cam for my Bolt-ons 2014 1SS Camaro
220/230 595/595 116+1 What you think about this cam and whats the WHP WTQ will be. Right now my car has TSP F-35 Camshaft 504 WHP 460 WTQ AirAid cai, 178 TSP LT, HI flow cats, 3'' Stainless exhaust pipe with stock mufflers. |
04-17-2021, 07:30 AM | #2 |
480/440. What’s the reason for swapping out the cam?
04-17-2021, 08:02 AM | #3 |
504 whp is very high for a cam already. Why change the specs? Is that a boosted cam?
04-17-2021, 12:09 PM | #4 |
Drives: Ashen grey, 1SS, L99 Join Date: Aug 2016
Unless that’s a boost cam I see you loosing power.
Roto-fab CAI, Nick Williams 102mm TB, LOD X1 V3 intake manifold, GMPP LS3 heads, Night Fury cam, TSP 2” long tubes, Corsa ZL-1 catback, Nitrous Outlet 102mm plate kit/150 shot, NGK BR7EF plugs with Taylor plug wires, DSX flex fuel kit, ZL-1 fuel pump and injectors, B&M deep trans pan, Yank 3400 converter, 3.45s with BMR Delrin bushings, mishimoto 169° Thermostat, GM ground effects, T-Rex upper grill, Z/28 Spoiler, Lolly pop Lime brake calipers, ZL1 10 spoke wheels, 12” subwoofer, and custom paint matched interior.
04-17-2021, 03:20 PM | #5 |
Drives: 2015 1LE Join Date: Oct 2015
Im guessing 470 to 480. Why did you switch cams?
2015 1LE, TSP 225/236 113+3, VMAX Throttle Body, CAI with race scoop, GPI Ported Intake, Land Speed Stage 2 Heads, 1-7/8 headers, NPP exhaust, 25% Fluidampr, LT1-S Monster Clutch, 485 RWHP & 444 TQ
04-18-2021, 05:51 AM | #6 |
Thank you all,
I'm living in Bahrain, laws are restricted here so I'm looking for a cam with smooth idle to pass the annual inspection and the checkpoints |
04-18-2021, 10:58 AM | #7 |
Drives: 2013 2SS Join Date: Mar 2014
Damn! I thought Kalifornia was bad.
05-04-2021, 01:37 PM | #8 |
I am expecting at least 25hp lost peak, with some good gains down low. Obviously the top end won't pull as hard as before, but the low end should feel more responsive.
Obviously I am just guessing based on cam comparisons. My guess is around 475/440, assuming that your original dyno pull was a bit on the high side.
05-04-2021, 01:55 PM | #9 |
Drives: 2010 CGM Camaro SS Join Date: Dec 2016
In for what you experience. I just installed an almost identical spec cam. 220/230 117 lsa. Made 447/440. You will lose whp from where your current setup.
Make sure to follow up with how it does. My car is at the installer now, haven't driven it yet. |
