04-06-2021, 08:12 PM | #1 |
Drives: 2015 2SS/RS 1LE Join Date: Dec 2020
Which Cam?
Looking for some help on selecting a cam. I've got a 2015 1LE m6 with TSP 1 7/8 LT's and Cai. Car is weekend/ nice weather only car. Looking at the TSP F-35 cam and the GPI SS4 cam. Hoping to make at least 500 to the tires. Thanks in advance!
2015 Camaro 2SS/1LE M6
CAI, TSP 1-7/8 LTs, more to come soon! |
04-06-2021, 09:09 PM | #2 |
2&THEHIT
Drives: 5th Gen Camaro; 5th Gen Ram 3500 Join Date: Mar 2018
04-06-2021, 10:26 PM | #3 |
Can’t go wrong with either cam. I’m a little biased to my Tick Polluter Stage 3
04-07-2021, 04:11 AM | #4 | |
Drives: Ashen grey, 1SS, L99 Join Date: Aug 2016
GPI cam IMO.
Roto-fab CAI, Nick Williams 102mm TB, LOD X1 V3 intake manifold, GMPP LS3 heads, Night Fury cam, TSP 2” long tubes, Corsa ZL-1 catback, Nitrous Outlet 102mm plate kit/150 shot, NGK BR7EF plugs with Taylor plug wires, DSX flex fuel kit, ZL-1 fuel pump and injectors, B&M deep trans pan, Yank 3400 converter, 3.45s with BMR Delrin bushings, mishimoto 169° Thermostat, GM ground effects, T-Rex upper grill, Z/28 Spoiler, Lolly pop Lime brake calipers, ZL1 10 spoke wheels, 12” subwoofer, and custom paint matched interior.
04-07-2021, 06:30 AM | #5 |
GPI gets my vote! Love mine
04-07-2021, 07:01 AM | #6 |
Drives: 2015 2SS/1LE Join Date: Aug 2016
Between those two cams listed, I would go with GPI. To reach 500 wheel, as others have said, will take more than a cam. Good luck, you will love having a cam!
SOLD 2015 - 2SS/1LE l Livernois 2RMax Cam Package l Livernois Ported Heads l BW Ported Throttle Body l TSP 1-7/8 Headers l CAI Intake l Factory NPP Exhaust l MSD Plug Wires l 508whp
04-07-2021, 07:30 AM | #7 |
Add ported cylinder heads. I ran the F35 for a while with PTC 260 heads. Ran great.
04-07-2021, 08:37 AM | #8 |
Drives: 13 1LE 1SS/05 ZX10/02 Silverado/14 Join Date: Nov 2014
FBO, SS4, Bo white TB, GPI rod-mod and ported intake and GPI tune in my 13 1LE got me 490 to the wheels so you can get close. My vote is for the SS4
02 Stepside Silverado
05 ZX-10 13 1LE 14 Nightrod Special |
04-07-2021, 08:49 AM | #9 |
Drives: 2012 camaro 2ss rs L99 Join Date: Feb 2017
GPI
2012 2SS/RS, L99, no cats/mufflers, Ported intake manifold, fuel rail upgrade, ID1050x injectors, Vmax throttle body, 25% UDP, GPI DOD delete, GPI SS3, GPI cnc heads, GPI – 5/16″ Hardened Pushrods, BTR trunion upgrade, BTR .660 springs, pcv revamp w/dual catch cans, Circle D 3800, full BMR suspension & bushings. ZL1 fuel pump, HPT programmed fpcm. JMS bap, Snow VC-50 methanol setup. custom 4gal methonal tank, vs7875 turbo, FMIC, precision 46mm WG, 50mm BOV, 3bar map, SJM line lock, Innovate SCG-1, Hurst shifter with tap shift mod, ×2 Holley 14" fans Diy E85, Diy auxiliary pump
04-07-2021, 04:59 PM | #10 |
Thanks for the input, I appreciate it. Going to have rod mod done as well.
04-07-2021, 05:53 PM | #11 |
Drives: 13' 1LE Join Date: Apr 2012
Both great for a max effort build. 1LE long ratio's suck BTW. Big down side at the track with a big cam, even on the streets, its not the best with the big 20'' wheels. Look at a FAST 102(overpriced but the 102mm TB is good for some hp). At least get rod mod intake, 102mm TB opening if your shop can do it.
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me. |
04-07-2021, 07:31 PM | #12 |
You know what else you should do..... a supercharger.
04-07-2021, 09:51 PM | #13 |
If I had the extra $$$, a procharger for sure. Goal is at least 500Hp & high 11's to low 12's. Have a K&N cai, but going to buy a rotofab.
Is it worth upgrading cam to 8620? Seems worth it
04-07-2021, 10:32 PM | #14 |
SomeguyK
Drives: 2010 Black 2SS/RS Join Date: Nov 2014
Add heads to the build for 500hp.
More to come. |
