04-02-2021, 01:40 PM | #1 |
WHAT SPARK PLUG AND GAP
Hey guys, so ESS system is on its way. You can see my engine mods in my sig already. I'll be running roughly 10lbs. Seems most run an NGK TR7. What gap would you guys run? Thanks
04-02-2021, 02:02 PM | #2 |
0.028" - 0.032" my new tuner put me in that range.
Juiced motor sports didn’t even gap my plugs correctly, hence why I was breaking up at high rpm (sigh****)
04-02-2021, 02:04 PM | #3 |
Served USN - Atomic Chimp
Drives: 13 Camaro LSX434 TT M6, 21 ZLE A10 Join Date: Jul 2012
0.028" can carry you up to 13-15psi boost and still get a nice idle
04-02-2021, 03:35 PM | #4 |
Awesome, thanks guys. So the NGK TR7 is good to go as well?
04-02-2021, 03:43 PM | #5 |
Drives: 2014 Camaro 2SS Join Date: Feb 2015
Best thing to do would be to read your plugs, and not just throw in whatever.
04-02-2021, 04:19 PM | #6 |
That’s what I use, and theyve been great.
04-03-2021, 06:44 AM | #7 |
Awesome, thank you very much!!
04-03-2021, 09:18 AM | #8 |
Drives: 2013 ss2 vert l99 Join Date: Apr 2017
Br7ef at 28-30.. if its not misfiring at WOT then you dont need a tighter gap.
04-04-2021, 06:08 PM | #9 |
Sucker Punch
Drives: 2013 Black ZL1, 2007 Silverado LTZ Join Date: Jul 2014
NGK TR7 .028 - .030, 15 - 17 PSI no break up and good idle.
427 Dart SHP Pro LS Block, Callies Magnum Crank, Callies Ultra I Beam Rods, Diamond Pistons, AGP twin Turbos 6865, Mast heads, Cam Motion LLR cam, Morel tie bar lifters, Crower roller rockers, NW 103MM TB, ID2600 XDS, Fore Triple, DSX, E85, ARH Turbo Headers, Corsa, Jakes stage 5 4L80, Circle D, RPM Roll Bar, BMR, Carlyle Racing 15" conversion kit.
04-04-2021, 08:55 PM | #10 |
Ive run the ngk tr7ix at 32 and the ngk br7ef at 32. I dont see any real difference between the two perfomance wise. The br7ef is copper non projected tip plug, which is supposedly safer if you’re planning on running alot of boost. They are much cheaper... like $2 each. If staying arpund 10psi I would probably stay with the IX plug, but theyre expensive, maybe have a slightly better idle. Thats what Jannetty recommends anyway.
Great to hear another ESS kit going into a camaro. Let me know if i can help in anyway.
2011 Camaro SS---SOLD
04-05-2021, 09:53 AM | #11 | |
04-05-2021, 02:20 PM | #12 |
Drives: T Join Date: Mar 2015
Tr7ix has been good to me. I had ZR1 acdelco plugs and a tuner recommended i swap for these before the tune, Zero break up. They come ready to roll out the box as well, no need to fuss around.
04-05-2021, 11:03 PM | #13 |
Great to hear. I gapped my tr7s at .30. Should be good to go
