03-22-2021, 03:07 PM | #1 |
Crank Case Venting
For you high HP boosted guys, what are your setup to relieve crank case pressure. I have the Mighty Mouse Wild Catch can, which I thought would work, but it didn’t. I want to keep that setup, but what other configuration can I do.
I chatted with Mighty Mouse and they said I can put a pcv line from the driver cover to the filter/charge pipe of my ECS blower. However, I would think it will pull oil in the S/C doing it that way.
03-22-2021, 04:41 PM | #2 |
I run 2 catch cans. One dirty side like yours and one clean side like Mighty Mouse suggested.
03-22-2021, 05:01 PM | #3 |
You ever pulled oil? What catch can for the driver side?
03-22-2021, 05:13 PM | #4 |
Served USN - Atomic Chimp
Drives: 13 Camaro LSX434 TT M6, 21 ZLE A10 Join Date: Jul 2012
Interesting.... I have my MM installed like yours (but with the check-valve on the can connector instead of inline like your gray color check-valve). In addition, I have a small vent can installed on my driver's side valve cover connector on the rear of the valve cover. I can run 27psi boost so far...
03-22-2021, 06:01 PM | #5 | |
03-23-2021, 02:26 PM | #6 |
GrINned & JUICEd
Drives: 15STI, 10Expy, 10 2SS/RS M6, 47KB1 Join Date: Nov 2009
What's the purpose of the filter on top of the MM can? Is there a check valve associated with it to vent to atmosphere if there is pressure? Similiar to the CFM breather. What's the routing of the clean side? I'm guessing that the check valve connected inline with the hose to the intake is to prevent boost pressure from going into the can and crankcase. Could it be installed backwards or not working correctly? Is there an arrow on the valve? Does the other check valve mentioned serve the same purpose? At idle, if you remove the line at the oil filler, you should have vacuum pulling towards the can. It may buck and stumble when you pull it off, due to unmetered air entering the intake.
Most catch cans have 3 ports for supercharged applications. Or use 2 cans.
03-23-2021, 03:33 PM | #7 | |
Not sure why he has two check valves installed (MM includes one in the can fitting and he has the gray one inline). I have seen oil spattering (as seen in his picture) when my catch can is filling up, needing to be drained.
03-23-2021, 03:40 PM | #8 |
You asked to see my 2nd installed catch can on my driver's side. It only serves as a secondary path to vent crank case pressure. It's connected to the rear vent port on the driver's side valve cover. So far 27psi boost and no blown main seals.
03-23-2021, 04:55 PM | #9 |
Easiest way to prevent seals from popping out is to vent both valve covers to a can that has a filter on it. Now if you want a dual purpose system that actually cleans your air, then it gets more complicated. I have noticed, with my cam, and driving frequency, i dont really need one. I pulled the intake a while back and there was 0 signs of oily residue.
Let the boost out or you will be pulling your motor to fix seals. Sucks.
2011 Camaro SS---SOLD
03-23-2021, 07:15 PM | #10 |
2&THEHIT
Drives: 5th Gen Camaro; 5th Gen Ram 3500 Join Date: Mar 2018
I’m not nearly high hp or high boost but I run Motion raceworks burndown tubes with their catch can venting each cover with an10 hose.
03-23-2021, 08:54 PM | #11 | ||
I’m thinking of altering my setup. 1. Keep MM wild setup- oil fill to the can, then hose from can to intake/tb nipple. 2. Vent filter breather on driver side (no check valve) 3. Vent filter breather connected to valley nipple (with check valve). Will this work? What can be swapped?
03-24-2021, 12:39 AM | #12 | |
GrINned & JUICEd
03-24-2021, 12:54 AM | #13 | |
GrINned & JUICEd
03-24-2021, 06:48 AM | #14 |
Nothing is connected on the clean side.
