11-07-2020, 05:42 PM | #1 |
Belt woes...
Any recommendations on a replacement belt for ECS 1500? Belt was never put on correctly from the beginning. Got it straightened out a couple of months back, but I’m sure it messed up the structural integrity. Edge of the belt sheered off.
11-07-2020, 05:52 PM | #2 |
Dan
Drives: 2010 Camaro 2SS IOM Join Date: Nov 2013
Look up gates - what numbersare on the belt?
Dan
2010 IOM SS YSI-B, Pat G Cam, Ported CTS-V Heads, ARH LTs MBRP 3" exhaust http://www.camaro5.com/forums/showth...&highlight=ysi |
11-08-2020, 03:19 PM | #3 |
Evil Genius of Chevrolet
You using an 8 or 10 rib?
11-08-2020, 05:30 PM | #4 |
Gates green belt.
11-08-2020, 07:30 PM | #5 |
11-08-2020, 09:16 PM | #6 |
I have no idea. Haven’t checked yet. What am I suppose to for?
11-09-2020, 06:59 AM | #7 |
Mine are 10 rib, but it should be something like K100749HD (10pk1903) K100745HD (10pk1893).
Ive also had good luck with the Continental Elite Poly-V belts. 4100577 (10pk1920) But like I said, those are all 10 rib belts in the 75 1/2'' - 75 1/8' range.
2011 Camaro SS---SOLD
11-09-2020, 09:53 AM | #8 |
I’m assuming it’s pretty easy to swap.
11-09-2020, 01:06 PM | #9 |
Dan
To take the belt off - use a 1/2 breaker bar and insert it in the square hole on the tensioner. Then take the pressure off the tensioner and you can slip the belt off - there should be a part number on the belt - you can then order a new one. Post up the part number - I may have one on hand - I have three others, maybe have the right length...
Dan
11-26-2020, 07:57 PM | #10 |
Finally had a chance to look at the car. NO P/N. :(
11-26-2020, 09:21 PM | #11 |
'It's an experiment'
Gates RPM belts if you can find your size...
-Don
747 RWHP 794 RWTQ
"Horsepower sells cars, torque wins races." - Enzo Ferrari See My Build: http://www.camaro5.com/forums/showthread.php?t=385577 |
11-26-2020, 11:10 PM | #12 |
Dan
Call up ECS and find out was size was shipped.
Dan
11-26-2020, 11:23 PM | #13 |
Easy way to find out belt length?
11-27-2020, 03:38 PM | #14 |
Dan
Measure the inside circumference with a peice of string, then measure the string.
Dan
