08-30-2020, 04:21 PM | #1 |
Pros and Cons of Snow/Alky/AEM Meth kit
Looking to add a meth kit. Which brand is more favorable and why?
08-31-2020, 04:49 AM | #2 |
Are you FI or NA?
Orange Krush II
08-31-2020, 05:40 AM | #3 |
i bought the devils own meth system and used the aem controller. its a cleaner and simpler install,
22% lower/ 2.5 upper/ 2” headers/ cat delete/ x-pipe/ 2 gallon x tank/ 100-3 pump/ fic 850/ dsx aux kit/ 103mm throttle body/ RPM 5” intake/ meth kit/ prometh lid injection/FI interchiller/ 160* stat/ ngk-7/ msd wires/ elite catch can/ tsp cam/ Che trunnions/ ported supercharger/ 1/2” lid spacer/ brick mod/BMR toe and trailing arms/ 751hp 757 tq SAE @17.3lb on a loaded dyno.
08-31-2020, 06:48 AM | #4 |
08-31-2020, 07:02 AM | #5 |
I was leaning towards AEM bc of the controller.
08-31-2020, 09:23 AM | #6 |
Drives: 2011 Camaro 2LT Join Date: Oct 2018
The AEM controller is nice. I suggest that you scrutinize the components of each kit. I’m going with the ALKY kit for that reason. The braided steel lines and brass fittings are a nice improvement over kits with plastic tubing and quick connect fittings. Although the ALKY controller is a bit archaic looking.
08-31-2020, 10:35 AM | #7 |
Really just want a system that I don’t have to dick around with, has a fail safe.
08-31-2020, 01:22 PM | #8 |
If you want safe, stay away from Meth just tune it correctly on the E85. you can piss on the fire if you like but you will just lose power if you are simply adding meth and not tuning for it. Tune for it for gains and to run right but then if you have an issue with the meth injection, BOOM
08-31-2020, 01:50 PM | #9 | |
08-31-2020, 03:29 PM | #10 |
Don't waste your money stacking meth on e85.
08-31-2020, 04:32 PM | #11 |
Wouldnt net anything??
08-31-2020, 05:47 PM | #12 |
Drives: T Join Date: Mar 2015
i think there are a few ways to use it. In your scenario you are running on the raggedy edge of what your blower can do, heat and IAT's surely can be improved. Will you gain tons? i think people see like 30 40 horse, but what you really do is change the IAT's and protect from detonation beyond what E85 does, maybe your local station has a bad batch of corn gas, im sure the methanol will help pick up where the CPU will pull timing.
All the highest HP stock block engine cars i have seen 900-1000 hp stock motor with boost are all E85 with a alky kit. |
08-31-2020, 06:50 PM | #13 | |
08-31-2020, 10:22 PM | #14 |
No, unless you are pumping meth all the time. Which is wasteful. If you kick it in at say 50% TPS, your tuner will have to pull fuel, e85, or you will run rich. Under those circumstances, if your meth pump fails, boom. Just get a good e85/premium tune and be happy.
