Old 12-03-2019, 10:15 AM   #1
eLeSthree
Drives: 2011 Camaro SS 6sp
Drop in piston/rod upgrade?
I see Vengance Racing offers a drop-in piston/rod upgrade for the LT1 crowd, that does not require rebalancing.
Does anyone know if this exists for the ls3, and if not why?
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT
1158whp 1017wtq.
2010 CTS-V A6 - "Stock" SOLD
630whp 658wtq
2024 F-150 RCSB 5.0 4x4
waiting for tunes...
eLeSthree is offline   Reply With Quote
Old 12-03-2019, 10:34 AM   #2
ntncoronado1
Drives: 2010 SS
I dont think you have to balance rods and pistons. I think that's optional.
Sent from my SM-G973U using Tapatalk
ntncoronado1 is offline   Reply With Quote
Old 12-03-2019, 10:43 AM   #3
eLeSthree
The crank is what gets balanced. Changing the piston or rod requires a rebalance. Unless you have exactly matched the "bob weight" of the new piston/rod/ring combo.
1158whp 1017wtq.
630whp 658wtq
Old 12-05-2019, 02:38 PM   #4
bct10985
Ive wondered this too. I havent seen anything advertised as “drop in”
Old 12-05-2019, 03:07 PM   #5
G8One2
Drives: 2014 Camaro 2SS
Idk how that would be possible without measuring the bore and selecting a piston. Then there's ring end gap that needs to be checked and or adjusted. Even stock pistons have grade differences for proper piston to wall clearance. Idk how GM does it, but where i work, pistons are select fitted like bearings, after the bore is measured. I suppose it "could" work as a drop in, but I'd be weary of it IMO.
G8One2 is offline   Reply With Quote
