11-03-2019, 07:39 PM | #1 |
Trouble_SM
Drives: 17' Summit White ZL1 Join Date: Jan 2015
Boosted LS3 sbe record broken
Took the car out to a private track rental this past Friday night and ran a PB, which I believe is a boosted LS3 record.
2015 1LE RPM stage 5 4L80e 4000lbs race weight (half tank gas) and me in it IPS twin turbo street kit wGarrett twin 61’s Stock bottom end LS3 (stock pistons, rods, crank and heads) https://youtu.be/0NLK2oR1FyE Last edited by graf101; 11-03-2019 at 08:27 PM. |
11-03-2019, 07:57 PM | #2 |
Drives: 2013 1SS 1LE Join Date: Jun 2016
That's movin!!!!!
603 h.p. 495 ft lbs tq. |
11-04-2019, 06:14 AM | #3 |
2&THEHIT
Drives: 5th Gen Camaro; 5th Gen Ram 3500 Join Date: Mar 2018
11-04-2019, 07:55 AM | #4 | |
2010 C6 JET STREAM BLUE
BOLT ONS TO THE EXTREME, GPI 281cc HEADS, Darth_V8r SPEC CAM, FAST 102 INTAKE, CRANK SCRAPER, QUARTER MASTER 7.25" CLUTCH, RPM 3.90 STAGE II DIF, Z51 Gear Set AND E85 Best ET 10.58 @ 131.8 stock heads and stock cam 453/445 SAE 10.62@134.82 GPI 281CC Heads, SS4 Cam and X1 Intake Best 1/8 6.80@105.75 Best MPH 134.82 |
11-04-2019, 09:35 AM | #5 |
Trouble_SM
Yes, that is a 6.0
11-05-2019, 07:24 PM | #6 |
Thats wicked!!
What suspension parts are you using?
11-05-2019, 07:43 PM | #7 |
Drives: 2011 Camaro SS Join Date: Jul 2017
Badass!!
11-05-2019, 08:55 PM | #8 |
Trouble_SM
BMR, Carlyle 15” conversion and Viking coilovers.
11-06-2019, 10:00 AM | #9 | |
Drives: 12 camaro ss, 72 chevelle, 91camaro Join Date: Dec 2013
11-08-2019, 11:45 AM | #10 |
Drives: 2015 Camaro SS commemorative Join Date: May 2015
what kind of boost do you see out of those 61's?
2015 Camaro SS, LS3 Stroker, PRC heads,CUSTOM CAM. AGP 68/68 with custom Hot and Cold side. Fore triple pumps, Holley terminator X. BMR drag suspension with carlyle brake kit. 15" ET drags and 17" skinnies. ZL1 3.73 gears , aluminum driveshaft. TH400 with circle D converter.
11-08-2019, 11:53 AM | #11 |
Trouble_SM
They are pretty much maxed out at 17-18lbs.
11-15-2019, 08:05 PM | #12 |
Drives: 2012 camaro ss ls3 Join Date: May 2014
u have viking coilovers in front an back
11-15-2019, 10:16 PM | #13 |
Trouble_SM
Stock suspension up front and Viking in the rear.
11-16-2019, 12:47 PM | #14 |
8.60 @ 157 @ 4200lbs
Suspension
Good job
2010 camaro twin turbo 8.60 @ 157 full weight 4200
Thread Tools | |
