08-06-2016, 10:25 PM | #1 |
Drives: Camaro Join Date: May 2016
o2 sensors
I can not figure out how the hell to get the o2 disconnected from the back of the cylinder heads......
08-07-2016, 08:24 AM | #2 |
From the back of the cylinder head????
2014 L99 2SS. 595HP/571ft-lbs
Mods: LSA Conversion 2.5" Upper Pulley, 65# injectors, GPI SS1 Cam, SP Long Tubes, ADM Race Scoop & CAI, NPP exhaust (DIY control), BMR 1" lowering springs, ZL1 Rear Differential / Axles, CF Side Strip / Hood Spear, Tint - Windows / Tails / Sidemarkers, Splash Guards, ADM Boost Gauge, ABL Dashkit, '68 Script Badges, ACS T4 Splitter, ZL1 Rockers from Gary's, Z28 Spoiler, Carbon Fiber Hood Vent, Summer - MRR FS01 Satin Black (10" Front 11" Rear) Winter, pictured-Drag DR 64's Satin Black (9" Front-10" Rear.) |
08-10-2016, 09:06 AM | #3 | |
High Angle Hell
it took me a lot of pain and suffering to disconnect it. The easiest way I found was to get underneath the car and if you have noodle arms like me you can reach your arm up through the bottom, grab ahold of the little bracket and give it a few pushes up really hard. It will eventually come loose but keep in mind it rotates a little left/right. Hope this helps
Brothers don't always have the same mother Always remembered, Never forgotten |
08-10-2016, 09:48 AM | #4 |
Resident nomad
Drives: 2014 Summit White 1SS/1LE Join Date: Nov 2015
I feel your pain! When I installed my LTH's, had to reach around for the driver's side connection behind the head. Once you understand how it's connected, it's fairly easy to get it disconnected, but because of the angle, it's a bitch the first time. Once I got that one, the passenger side was a lot easier. If I remember right, you have to pull a green "t-pin" that otherwise prevents the retaining clip from being pulled open. Once that is done, you push "out" on the blue clip, and the two separate. I apologize if I have the colors mixed up, but you'll understand once you look at it. There is also a few DIY threads on here that show the connection up close, so you can figure it out looking at that.
I have to disagree with Infantryman above, only because I don't think you want to remove the connection from the head, just separate the O2 sensor harness where it connects there. Removing the connection from the head will give you more room to separate the O2 sensor harness, but you will still have to remove the two anyway. Plus if you break the attachment at the block, you'll have to rig up another way to keep the harness up and away. Good luck!
Sold:
2007 Z06 2002 Viper GTS/ACR 2003 Z06 1965 FFR Cobra 2012 Nissan 370Z ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing. |
08-10-2016, 11:54 AM | #5 | |
High Angle Hell
Thread Tools | |
