09-30-2015, 03:21 PM | #1 |
Drives: 69 Camaro with LSA Join Date: Oct 2014
Lingenfelter oil cooler adapter SOLD
SOLD shipped lower 48 states. P/P ok wayniez28@aol.com
Description: I have a used Lingenfelter remote oil cooler adapter. Some scrapes and a ding in the front edge but nothing that will interfere with it working. This is how I bought it. What you see is what I have. It won't work for me. From Lingenfelter The Lingenfelter oil cooler adapter is designed to allow the installation of an engine oil cooler on GM Gen IV V8 engines including the LS1, LS2, LS3, LS6, LS7. The LPE adapter is machined from a single piece of 6061 aluminum and is then black hard coat anodized for additional durability. The adapter features -10 fitting for the oil inlet/outlets along with a port for the oil temperature sensor and oil feed line. This adapter was specifically designed to reduce oil pressure drop over other designs on the market, retains the factory oil filter location. Oil exiting the adapter is filtered oil. Oil feed port for accessories is oil returning from the cooler. [/URL] [/URL] [/URL] [/URL] http://www.lingenfelter.com/mm5/merc...4#.VgwyLZ5dGcw
69 SS/RS Camaro complete frame off new sheet metal. DSE mini tubs, frame connectors, tubular control arms. Ride Tech 4 link with coil overs and Chassis Works Fab 9. C6 Z51 Corvette brakes. GM crate LSA/4l85 crate drivetrain.
http://www.lateral-g.net/forums/showthread.php4?t=17217 Last edited by Wayniez; 10-01-2015 at 08:11 PM. Reason: SOLD |
10-01-2015, 11:07 AM | #2 |
Drives: 416 w/TH400 Join Date: Mar 2012
why wont it work for you and I'll take it let me know and I'll send PP
ERL 416 - 12.5 cr, TH400, Custom VVT Cam, PRC 255 heads, NW 102 TB, Aeromotive stealth fuel system, Fast 102 plumbed with a nitrous express direct port kit, BMR 15" conversion kit
10-01-2015, 08:10 PM | #3 | |
http://www.lateral-g.net/forums/showthread.php4?t=17217 |
10-02-2015, 09:25 AM | #4 |
damn
