03-25-2015, 05:45 PM | #1 |
Drives: 2013 v6 camaro ls Join Date: Jul 2014
LFX 2013 cams???
im just wondering if there is any news about cams for the lfx v6
03-26-2015, 08:12 AM | #2 |
Drives: '14 RRM 1LT/RS A6 Join Date: Mar 2009
https://www.google.com/webhp?sourcei...ww.camaro5.com
37000 results on Camaro5 you're welcome, good luck |
03-27-2015, 10:28 AM | #3 |
Drives: 2013 SW 2LT/RS LFX/AY6 Join Date: Feb 2013
Or simply reply "no" since there's no further news from any sources on them... anything dealing with cams needs to be custom done.
K&N CAI, 1LE Strut Tower Brace, Elite Engineering Catch Can and Clean Side Separator, Apex Scoop w/ Washer Relocation Kit, CTS Front Calipers and Rotors, JacFab Ported Intake Manifold, JacFab Intake Manifold Spacer, 80mm Overkill Throttle Body, SS Brake Lines, Ideal Garage Master Cylinder, Monster Twin Disc Clutch, NPP Retrofit w/ Magnaflow Resonated X, ARH Catless Downpipes, JRE Built 3.45 Diff, 1LE Axles, 1LE Hubs, Overkill Tuned, BMR Anti Wheel-hop Kit Stage I, ACS TL1 Hood Insert, ZL1 Spoiler
03-27-2015, 11:06 AM | #4 |
Drives: '14 1LS Join Date: Apr 2014
No, I think the cams have pretty much hit a dead end due to their complexity for the DI engine, cost, and unsure gains. FI is the way to go on the V6 or nitrous if you choose. I'm looking at the IPF kit or possibly the roots kit that has surfaced, if it produces decent gains.
Patiently waiting for my 2023 SS 1LE |
03-29-2015, 05:41 AM | #5 |
Drives: 2016 1SS SW Join Date: Jun 2013
BlackoutLFX and Jason@JacFab went through some ordeals trying to pave the way for this mod, but it just didn't work. BlackoutLFX had some difficulty dealing with Mace for their proprietary LFX cams, but it was all for nought. Jason, if I recall correctly, bought a set of LF3 cams and an LF3 intake to see if there was a possibility of making something happen, but there weren't any significant differences with the LF3 cams.
03-29-2015, 09:01 AM | #6 |
So in other words no. Lol go FI or nitrous for power
03-29-2015, 12:42 PM | #7 |
Drives: 2002 Z/28,1968 Chevelle convert. Join Date: Oct 2010
<~~~~~~~ wish we had access to heads/cams ....... would be nice ....
03-29-2015, 02:38 PM | #8 |
You do have access to heads and cams. It's just gunna have to be custom. I've even considering buying a set of oem heads to send them out to get ported to test the gains. But as far as cams go it's going to be expensive because it's not just one or two cams your dealing with. And on top of that I believe there are certain lobes that require attention. So is it possible yes. But it's going to be expensive custom work from a quality quality can specialist. And the gains may or may not be worth it. That's why the tried method for power on the LLT and LFX are nitrous and FI.
04-14-2015, 09:42 PM | #9 | |
Drives: Ly7 Join Date: Dec 2011
https://www.facebook.com/SVSCairns?fref=ts There is a video and a dyno graph. SVS in Australia has made 250rwkw, with a set of Mace Engineering Group camshafts for the LFX. Started at 190rwkw and the end result was around 250rwkw. So a jump of about 80rwhp with other mods like cold air intake etc. Turns out that all this time it was in the tune!! Tuners not knowing how to effectively tune for SIDI There has also been lots of recent successes with LLT's as well using HPTUNERS Last edited by kuzman89; 04-14-2015 at 10:27 PM. |
04-15-2015, 01:24 PM | #10 |
Drives: 16 Camaro SS, 15 Colorado Join Date: May 2009
Holy Crap
That's amazing. I did the HP and TQ conversions. Went from 256RWHP to 335RWHP and 214RWTQ to 260RWTQ with different intake, cams, and tune. I want to know more about this magical tune, and can LFX owners in the states get it? Also, did MACE change the cams again recently, or was the problem all in the tune? I know MACE recently said their LLT cams were ready, but their LFX cams were not. I guess that changed? Love this update. Deserves its own thread.
2010 Camaro 1LT V6 (Sold. I will miss her!) |
04-15-2015, 02:49 PM | #11 |
The gritos pollo!!!
i want! x2 where do we find this magical cam and tune package?
______
If you don't stop how can they give you a ticket?-The Big Tuna___ '12 1Ls Camaro; Slp loud mouth I|maganflow x-pipe|Injen long ram intake|brembo brake upgrade| russell s.s. lines|2LT polished 19's|billet 5mm spacers|tinted tail lights&markers|pdmi|billet c. can| '13 Avenger R/T '77 T/A 6.6;, draining my wallet. |
04-15-2015, 06:32 PM | #12 |
Drives: 2016 Bright Yellow 2SS A8 Join Date: Jul 2014
Yeah, I want to know about this also. Those gains are pretty significant.
04-15-2015, 07:02 PM | #13 |
Drives: '13 2LT/RS Twin Turbo Join Date: Aug 2012
7800rpm? 8500 plus on a built motor? Damn!
04-15-2015, 08:54 PM | #14 |
Drives: 2014 v6 Join Date: Nov 2013
X3
