02-21-2015, 09:36 PM | #1 |
Drives: 2013 v6 camaro ls Join Date: Jul 2014
turbo camaro costs???
im looking into buying a turbo charged camaro ss and i was just wondering how much does it cost to maintain it. are there any certain things u need to do?
02-21-2015, 09:38 PM | #2 |
Drives: 2014 2SS M6 "CHRISTINE" Join Date: Mar 2014
Besides have a huge bankroll? Nah, nothing.
Mods: ARH headers and hi flow cats, VMAX ported throttle body, CAI air intake, Slowhawk Performance tuning |
02-22-2015, 07:58 AM | #3 |
Jumanji
Drives: '14 Z/28 - AGM - No A/C Join Date: Mar 2014
Street car? Track car? How much power? Single or twin turbo? Is the engine built for the power? Intercooler type? What electronics does the car have? Turbo timer? How long has the system been on the car? What brand is/are the turbo (s)?
Anything done to the transmission or chassis? |
02-22-2015, 12:04 PM | #4 |
Turbonetics 76mm turbo, Borla ATAK exhaust, ZR1 cam, DOD delete, top end upgrades (springs, pushrods, bolts, etc), Boost a pump, injectors,Mildly tuned with 8psi 580hp and 585 tq 2012 v8 camaro
02-22-2015, 08:27 PM | #5 |
Too much is never enough!
Drives: AGP TT SS [COTW] 4/20/15 Join Date: Feb 2014
If you think in terms of worst case scenario then figure on rebuilding the turbo. Other than a cam failure, there really isn't any "extra" cost. The general rule of more power more money will always apply, but that power level isn't insane, and your far from stressing the stock bottom end.
AGP TT kit, 54/57 Forged rotating assembly, Custom grind cam... Dual nozzle meth, ID850's, Livernois dual fuel pumps, ECS BAP, 25% UDP, 3 inch Magnaflow catback with X pipe, Mantic 9000 clutch, DSS 1000hp axles, DSS aluminum driveshaft, ZL1 rear end, solid subframe bushings, HE differential offset bushings, BMR Trailing arm, BMR toe rods, Lingenfelter LNC-2000,SJM Line Lock. 747 whp 714wtq
Build thread http://www.camaro5.com/forums/showth...55#post8107855 |
02-22-2015, 08:57 PM | #6 | |
Drives: 2012 M6 Camaro SS (RIP) Join Date: Nov 2014
the ZR1 cam is pretty stout, so you could probably crank the boost up a little more and be fine. |
02-22-2015, 09:57 PM | #7 |
I hardly wait at all. At 3k RPM's im already over 550wtq and close to full boost.
Build thread http://www.camaro5.com/forums/showth...55#post8107855 Last edited by 1KillerSS; 02-22-2015 at 10:32 PM. Reason: Originally said Tq not Hp its Wtq |
02-22-2015, 11:49 PM | #8 |
Drives: ‘13 1LE Join Date: Jul 2013
Very passé this kind of thinking, I still see this in SC vs Turbo threads.
It's all about size optimization, and optimum efficiency for given application, but even with variable vane technology, etc, some cars out there are at full powaaa, right off idle practically . I believe you! |
Thread Tools | |
