07-15-2017, 08:21 PM | #211 |
Drives: 2013 ZL1 A6 #4801 Join Date: Mar 2016
Nice numbers...
07-15-2017, 09:50 PM | #212 |
07-15-2017, 09:51 PM | #213 |
A6
pullies cam headers intake heat exchanger |
07-30-2017, 04:21 PM | #214 |
Drives: 2012 ZL1 125HP kit , EIBACH springs Join Date: Jul 2012
Jannetty 125 HP Kit
Just got my car back from Ted. 125 kit is a nice upgrade from stock. Also had Eibach springs and Pedders sway bars installed.
08-01-2017, 01:05 PM | #215 |
Drives: 2013 Camaro ZL1 & 1979 10.5 Camaro Join Date: Jul 2016
08-06-2017, 10:45 PM | #216 |
2015 M6 with 7500 miles,I am not the 1st owner so I can't comment on the break-in procedure. Temp was around 85 with about 75% humidity.
Mods: Rotofab CAI with Big Gulp Kooks 2" headers with cat-less mid pipes 160 degree t-stat New Age Hot Rods Dyno video: https://youtu.be/uZB3mE2Cvf4
2015 Camaro ZL1 - 769RWHP 755RWTQ Mods: RPM 5" intake, Kooks 2" headers w/o cats, 9.1" lower, 2.55" upper, Kong performance ported blower/snout, NW 102mm TB, afco hx w/ fans, RPM cam package, ID1050x injectors,160 degree t-stat, Tuned by Fran at RPM
Best 1/4 mile: 10.99@127 Dyno graph YouTube 2003 C5 Z06 - SOLD Mods: 455 RWHP 415RWTQ FBO and FTI Street Sweeper Cam (236/240 .631/.612 111 lsa) Last edited by OneBadvATE; 08-07-2017 at 10:21 PM. |
09-09-2017, 09:52 PM | #217 |
GMHIC
Drives: 2013 Camaro ZL1/2008 Pontiac G8 GT Join Date: Apr 2010
I made 609 rwhp/ 591 lbft. I was hoping for more, but considering my baseline was low and the blower was only making 8 psi with the 9.55 lower and running 91 octane, I don't feel too bad. I'm sure if I add a 2.75" upper, port the snout w/ along with a larger throttle body, I can pick up some additional boost and possibly make 650+.
My mods are as follows: Corsa 3" catback Stainless works 2" primary LTH Injector Dynamics 1050x injectors DSX aux fuel pump New Era 4.5" cold air intake New Era Expansion tank REVSC custom grind PD camshaft BTR platinum .660 lift valve springs with titanium retainers BTR hardened pushrods ARP hardware, camshaft bolts, head bolts NGK plugs LS9 head gaskets 160 degree thermostat AFCO ZL1 heat exchanger without fans Innovators West balancer / Metco 9.55" lower drive
Pontiac G8 GT- ProCharger F-1D, Treadstone TR1235 FMIC, Kooks 1 7/8" LTH,Corsa catback, New Era (228/240) cam, Yella Terra 1.7 Rockers, GMPP LS3 CNC heads, Aeromotive A1000, FAST fuel rails, FIC 1000cc injectors - 762 RWHP/646 LBFT tuned @ 11psi on E85 using HP Tuners
Camaro ZL1- Stainless Works 2" LTH, Corsa catback, RSC PDx cam, ID 1050x injectors, DSX fuel kit, New Era 4.5" intake, BTR springs/pushrods, AFCO heat exchanger, New Era expansion tank, Innovators West balancer, Metco 9.55" lower - 609 RWHP/591 LBFT tuned @ 8psi on 91 octane using HP Tuners Last edited by incon3037r; 09-10-2017 at 01:37 AM. |
09-09-2017, 10:37 PM | #218 |
Drives: 69 Camaro with LSA Join Date: Oct 2014
NICE!
69 SS/RS Camaro complete frame off new sheet metal. DSE mini tubs, frame connectors, tubular control arms. Ride Tech 4 link with coil overs and Chassis Works Fab 9. C6 Z51 Corvette brakes. GM crate LSA/4l85 crate drivetrain.
http://www.lateral-g.net/forums/showthread.php4?t=17217 |
09-15-2017, 11:34 AM | #219 |
'It's an experiment'
My GPI Forged/Stroked LSA with Jokerz Ported blower!
Dyno (So rounded 747 RWHP, and 794 RWTQ) @ 13.5 PSI! -Don
747 RWHP 794 RWTQ
"Horsepower sells cars, torque wins races." - Enzo Ferrari See My Build: http://www.camaro5.com/forums/showthread.php?t=385577 |
09-15-2017, 12:06 PM | #220 | |
GPI Sales Consultant
Got a question about a GPI product? Feel free to shoot me a message! |
11-22-2017, 09:29 PM | #221 |
Drives: '15 Silverado LTZ & '13 ZL1 ragtop Join Date: Nov 2016
Final round of mechanical mods are in and E85 sensor is activated. Whp on 50/50 blend of E85 and 93 pump gas is 700 with 567 ft lbs of torque (some heat soak and a BTR3 PD cam).
Brian Tooley Racing Stage 3 PD Cam kit Kooks LT headers with cat deletes 2.85 Metco Upper and 9.17 Lingenfelter Lower Pulleys for 14.5 pounds of boost ATI Superdamper DST Ported Blower Snout & throttle body B3R Expansion Tank FIC 850 injectors ADM FPCM DSX E85 Sensor Devil's Own Methanol Progressive kit Deep Stage Tuning and Performance custom HP tune All that's left to do is put on a 3" full exhaust with resonators to mellow her roar and find some 18" replicas for slicks. https://youtu.be/BsuDLXLTkos https://www.ar15.com/media/mediaFile..._25-370644.jpg Last edited by leemozoid; 11-22-2017 at 10:03 PM. |
12-25-2017, 05:16 PM | #222 |
Steve
Drives: 2014 ZL1 Vert Red & 2012 ZL1 Black Join Date: Sep 2014
2014 Camaro ZL1 Convertible - 644 RWHP
Mike Norris tune 644 rear wheel horsepower, 647 foot pounds of torque
Red dyno numbers in upper 500 range are with the Lingenfelter tune All numbers and times are with 93 octane 11.407 quarter mile at 122.6 mph with Hoosier Drag Slicks 28x10-17 D06 Lingenfelter 700+ HP Package Lingenfelter Intercooler and Reservoir Lingenfelter Fuel Pump Booster Corsa Stainless Cat-Back Exhaust Elite Catch can Last edited by sulrich; 12-13-2018 at 11:52 PM. |
01-19-2018, 12:25 PM | #223 |
Drives: HSV LSA Gen f gts Join Date: Oct 2016
01-26-2018, 12:58 PM | #224 | |
764/661.
The only change we made from the last run was an upgrade in injectors from 850s to 1300s. We had some belt slippage so there was a drop in boost from 14.1 to 12.9 pounds shortly after the peak torque # was hit. A new belt has been ordered. Alcohol % was 58 for this run. E85 runs around 60% here. Quote:
