03-06-2017, 12:35 PM | #1 |
BTR PDS stage 2 results
Normally I do all the work on my own car but not having anytime to do work on it kind of sucks. I let the guys from Slowhawk Performance take care of this one for me. Talked to Don about what I was looking for with my set up and he came up with this. Idles like stock (really have to listen to hear the cam) and solid numbers without finding peak HP due to hitting the limiter at 6600RPM on the stock LS3
2010 Camaro SS Whipple SC, CAI Inc Intake, TSP 1 7/8" LT headers no cats, 3" magnaflow exhaust, HPT, RX Catch Can, LSR Toe Rods, LSR Trailing Arms, ALKY Control Meth, McLeod RXT Twin Disc, ZL1 fuel pump, 3.73 ZL1 Differential Kit, BTR PDS Stage 2 Cam, Tuned by SLOWHAWK Performance Bridgewater MA
03-06-2017, 09:12 PM | #2 | |
Drives: 2010 Camaro ss M6 Join Date: Jan 2015
Robert. |
03-07-2017, 04:01 AM | #3 |
Dan
Drives: 2010 Camaro 2SS IOM Join Date: Nov 2013
Nice! I went with a BTR PD Stage I cam for my YSi build hoping for some good results too...
Update: sold the BTR cam and bought a PAT G grind on a TSP 8620 core...optimized for a centri
Dan
2010 IOM SS YSI-B, Pat G Cam, Ported CTS-V Heads, ARH LTs MBRP 3" exhaust http://www.camaro5.com/forums/showth...&highlight=ysi Last edited by racesloth; 03-04-2018 at 07:23 AM. |
03-07-2017, 06:31 AM | #4 |
Thank you...the car feels lighter if that makes any sense, and with the whipple in stock form it already felt light to begin with
03-07-2017, 06:33 AM | #5 |
BTR PDS Stage 1 shouldn't disappoint at all. If I didn't have a stock bottom end on this engine I would have had the rev limiter raised to 7K and at that point might have found peak horsepower
03-08-2017, 11:47 AM | #6 |
Nice numbers! With the Whipple, you may not ever see your HP peak. I have the LS9 cam in mine, and she pulls all the way to my RPM cutoff, 6500RPM, without any dip in the HP curve. She just keeps pulling, and pulling, and pulling....
03-08-2017, 12:57 PM | #7 |
I'm just waiting for the weather to get warmer up here to really test it out...roads are cold and literally feel like you are on ice right now without getting into that GO pedal
03-08-2017, 06:55 PM | #8 |
Drives: 2010 Camaro SS Join Date: Dec 2006
Great numbers! I have this same cam in my garage waiting to go on.
03-09-2017, 07:20 AM | #9 |
I'm into the sleeper look / sound so this cam was perfect, not noticeable and really have to listen to hear it, but makes really good power
03-09-2017, 11:37 AM | #10 |
Drives: 2010 Camaro 2SS M6 - Intake/Exhaust Join Date: Sep 2014
Nice numbers....
11psi? |
03-09-2017, 09:01 PM | #11 |
Yes it peaked at the end of the pulls at 11.19 PSI...it's about as much as I want to go with the ZL1 pump and now 80lb injectors
03-11-2017, 08:30 AM | #12 |
Drives: 1999 Trans Am Join Date: Jul 2009
I wanted to go 15/16psi
03-12-2017, 01:54 PM | #13 |
04-22-2017, 10:45 PM | #14 |
Drives: 69 Camaro with LSA Join Date: Oct 2014
I'm going to try to make it up to Dyno day and talk to Don about my project. Your going to have a great summer with the new power. That's the only good thing about the rain up here it's getting rid of the salt on the road so you can sneak in an early ride. Nice!
69 SS/RS Camaro complete frame off new sheet metal. DSE mini tubs, frame connectors, tubular control arms. Ride Tech 4 link with coil overs and Chassis Works Fab 9. C6 Z51 Corvette brakes. GM crate LSA/4l85 crate drivetrain.
http://www.lateral-g.net/forums/showthread.php4?t=17217 |
