11-28-2016, 08:11 AM | #15 |
Drives: Camaro Join Date: Mar 2013
Does the 4L80 swap require modifications to the trans tunnel to fit?
PS I am already doing 1.56 60' with a M6 and 17s. I want low 1.4 with an auto swap. |
11-28-2016, 10:52 AM | #16 |
Drives: 2010 2SS LS3, 2013 duramax Join Date: Nov 2012
You have to cut part of the inner rail out for the trans plug and i beat the passenger side tunnel in a little with a big hammer
11-28-2016, 12:42 PM | #17 |
I'm going to have to bump the passenger side with my th400. It rubs.
12-16-2016, 10:44 AM | #18 |
Is there a big weight difference between the 4l80 and the tr6060?
Forged LS3 416ci, Maggie TVS2300 @ 13lbs boost, McCleod twin disc clutch, GForce 1320 nine-inch 389 gear ratio, Hurst line-lock, 750 whp 700 wtq |
12-16-2016, 12:09 PM | #19 |
I lost 40lbs going th400
12-16-2016, 12:32 PM | #20 |
Emerald Coast Camaros
Drives: 2010 RS/SS Rally Yellow & 68 SS Join Date: Dec 2012
Don't know about the tr6060 but the 4L is a pig.
Best @ 586/525 =10.41 @ 133
AS OF 12/13/14>633 RWHP =10.22@135 AS OF 1/31/15 @ 633 RWHP=10.16@135 AS OF 1/29/16 @ 633 RWHP=10.10@136 TOPED 700 PASSES AFTER F.I. AND STILL ON THE ORIGIANAL STOCK AXLE & DIFF |
12-16-2016, 02:16 PM | #21 |
The 4L definitely heavier. Ive taken the tr6060 out twice and the 4L out twice on jackstands in my garage.
12-17-2016, 05:05 AM | #22 |
My comparison. Full tank of gas with me in it on before and after. Th400
12-17-2016, 09:35 AM | #23 |
Well that makes me feel better now if we knew what a 4l80 weighs compared to a th400. I'll see if I can find that somewhere. I weighed in at 4060 with me in the car but I don't think I had the cage in it yet. Thanks for the input guys!
12-17-2016, 10:12 AM | #24 |
Jakes performance transmissions said the 80e weighs 38lbs more than the th400. So its pretty much the same as tr6060 or at least within 20lbs.
12-18-2016, 12:34 PM | #25 |
Good to know the difference between 3l80 and 4l80
