10-06-2020, 05:33 AM | #15 |
I'm pretty sure 800ish is do-able with your setup. You may need to add meth. The faster you spin it, the more heat it will make.
This is why I suggested the larger blower route. You're already back for more, hahaha.
2011 Camaro SS---SOLD
10-06-2020, 10:58 PM | #16 |
800 is the magic number.
11-16-2020, 12:03 PM | #17 |
Evil Genius of Chevrolet
You guys are running 15 psi on the sbe without internal problems? How is that possible? Every person I've spoke with has said no more than 10psi on the sbe or else you risk boom boom.
11-16-2020, 08:32 PM | #18 |
Drives: 2010 2SS LS3, 2013 duramax Join Date: Nov 2012
There are probably thousands of stock bottom end Ls motors out there surviving with more than 15 psi shoved into them.
11-17-2020, 06:28 AM | #19 |
I'm going to guess the trans doesn't survive long with that much boost. The 6L80 is def my weak point atm.
11-17-2020, 09:24 PM | #20 | |
A member on here. https://youtu.be/lGheg5_P_ZA
11-18-2020, 08:16 PM | #21 |
Dont get caught up with boost #’s its just air the motor cant take in. Mine makes around 20psi @ 7k rpm. Sbe
11-18-2020, 08:18 PM | #22 |
DAMN. That's impressive. Stout engines.
11-18-2020, 08:21 PM | #23 |
I was told on pump 10psi is the top for being safe. After that you need to add meth. Would going to 12 or 13 really do harm?
11-18-2020, 09:08 PM | #24 |
Too many variables to throw out a certain boost #. 100% stock engine?
11-18-2020, 09:16 PM | #25 |
GPI SS2 VVT cam with all supporting mods. ECS Novi 1500 currently at 9psi. FIC 1000 injectors. Headers.
