07-12-2020, 11:22 PM | #15 |
Damn 22k.
07-13-2020, 06:30 AM | #16 |
Drives: 2012 Camaro SS Join Date: Jun 2019
Yikes, $22k!
After I installed my whipple, I immediately wanted/needed to do suspension upgrades. Once you start throwing more power to the wheels, you really need the support to get the power to the ground. I got a lot more power with the whipple, but it wasn't good for much until I upgraded the suspension. Now, the car feels planted. I'd start with trailing arms, toe rods and at least cradle bushing inserts, that's what I did and it really made a difference, also, they're not that expensive.
2012 Camaro SS LS3, JRE Scoop, CAI intake, Whipple Supercharger, Fast 85lb injectors, ZL1 pump, McLeod RXT clutch, MGW shifter, Stainless Power 1 7/8 headers w/HFC, Ridetech coilovers, BMR sway bars, trailing arms, toe rods, cradle bushing inserts, 2020 Speed Tuned.
07-13-2020, 07:12 AM | #17 |
22K is a normal price for the mods mentioned. I don't have an auto, my path was supercharger first which got me to almost 600whp on 11psi. I would start there, you will want a tranny cooler as well. Then next year if you want more you can go with a cam, converter, ect. Just be realistic with your goals and build the fuel system once. You likely won't go over 700whp with the stock trans so ZL1 pump and JMS voltage booster would be enough. once you do the cam you are going to want to do the converter most likely, don't have to with just the SC.
07-13-2020, 08:22 AM | #18 |
ESS is 6500-ish
Converter in 700-800$ What else am I missing. When I did my build, and pricing ESS, I was nowhere near 22k
07-13-2020, 09:04 AM | #19 |
Drives: 2010 2SS LS3, 2013 duramax Join Date: Nov 2012
10.90 should be pretty easy with an auto. I went 10.9@125mph with a ecs novi1500, meth kit, Stock cam, some suspension, 17” drag radials with a manual transmission. Was making around 600rwhp at the time.
07-14-2020, 09:05 AM | #20 |
Cam, valvetrain, fuel system, oil pump, trans cooler, but most importantly the labor cost is what you are missing.
07-15-2020, 07:39 AM | #21 | |
Even for my whole build cam/headers/fuel/trans/labor/FI I’m at 16...
07-15-2020, 10:39 AM | #22 | |
If you find an estimate outside your budget you will have to lower your goals or your budget, then we can better estimate a job for you. Please don't minimize what we quoted you on, to make it sound overly priced or off putting. The estimate includes much more than a blower, a cam and converter. It included, full L99 to LS3 conversion, with Oil pump and C5rchain, Supercharger system with Optional upgrades, exhaust, complete fuel system upgrades for 700 RWHP, tune up parts, trans service dipstick tube oil filter antifreeze, thermostat, HPtuner license, Labor and dyno tuning etc etc. Many people call us with champagne taste on a beer budget. I always ask what is your budget and goals, then we don't waste time writing a huge estimate that is outside of your budget. Then I get well I don't have a budget the sky is the limit, so we throw the kitchen sink at it, and I find a post like this. As I tell everyone I do estimates for, if you feel this is not for you please give us the opportunity to re quote you on a package that better fits your budget. There are 3 things in building Cars, Fast, Cheap, Reliable. YOU CAN ONLY PICK 2. Fast and cheap, Not reliable Cheap and reliable, Not Fast. Fast and Reliable, Not Cheap. Ted.
www.jannettyracing.com
Celebrating 37 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705 email tedj@jannettyracing.com Last edited by JANNETTYRACING; 07-15-2020 at 11:13 AM. |
07-15-2020, 01:36 PM | #23 | |
I would in no way, or certainly did not intend to minimize what you quoted. I was shocked at first, but then spoke to a few people and came to the realization that I just did not have the money for what I wanted. One thing you need to know is that the last time I was building engines, was in the late 80's early 90's. Back then engines were carbureted and a camshaft cost $99. Today camshafts are $300 and there is a lot that goes into tuning these engines. I had a budget, but it was not enough to get what I wanted, so I had to step back and take another look at what I wanted. I am now trying to figure out the best route to take to get me to my original goal. If this helps, thank you. Ted, I am sorry if I came across wrong. I was taking a lot of your(shops) time trying to whittle this down. Once winter rolls around, I will be back at it and will certainly contact you.
2011 2SS/RS Convertible, Victory Red, Roto-Fab CAI, Stainless Power 1 7/8 headers, No Cats, Straight piped, Bo White TB, ZL1 CONVERSION, CDC Roll bar and some powder coating and dipping.
07-15-2020, 02:00 PM | #24 | |
All the more reason to go with this kit.
07-16-2020, 07:36 PM | #25 |
Why not ECS?
07-16-2020, 09:52 PM | #26 | |
Now I’m tuning the 427 with the G3X and its a beast. It might be a little small for this big effecient motor, but the G4X is coming soon. Gotta love not having to tap the oil pan also. There are a bunch of guys running thier camaro kits now, but not many on this forum. They make the G series for Mustangs and Corvettes as well.
2011 Camaro SS---SOLD
07-17-2020, 09:25 AM | #27 | |
I appreciate the opportunity to work with you on your project. I am happy to put an estimate together that better fits your budget. Always here to help. Ted.
07-17-2020, 01:12 PM | #28 | |
Put it on the rollers yet??
