TireRack
Old 01-20-2020, 06:57 AM   #1
eLeSthree
Drives: 2011 Camaro SS 6sp
Flex fuel sensor ID choking feed?
I've been struggling to get a good reading from my flex fuel sensor. I had it plumbed into the return under the car, no good. It only sees fuel when the return is full of fuel. Which is not all the time. If it reads 0% the ECM thinks im on 93 and changes my AFR and timing. Once the return line gets fuel in it, it reads %77 again and timing comes back.
So I moved it to directly under the regulator, thinking it would see at least a small amount of fuel, but no. Not all the time. Same problem.
DSX says it MUST be plumbed into the feed line, but the ID of the sensor is so damn small. Placing it in my -10 feed kinda defeats the purpose.
How can I run the FF sensor in the feed and not restrict flow?
Since I literally never run anything but Ethanol, can't I just ditch Flex fuel all together and run a strictly Ethanol based tune?
Can't I still use the FF sensor to verify E content (manually with laptop) when I fuel up, but not change the tune based off that content?
This is just my racecar/toy/weekend beater. I've put 3k miles on this car since 2015.
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT
1158whp 1017wtq.
2010 CTS-V A6 - "Stock" SOLD
630whp 658wtq
2024 F-150 RCSB 5.0 4x4
waiting for tunes...
eLeSthree is offline   Reply With Quote
Old 01-20-2020, 08:00 AM   #2
jasycz28
J.Sick
jasycz28's Avatar
Drives: 2010 Camaro SS
You could always Y the sensor into the feed side.
"J.Sick"
2010 Camaro 2SS
jasycz28 is offline   Reply With Quote
Old 01-20-2020, 08:32 AM   #3
bct10985
Could do it like this
Old 01-20-2020, 08:49 AM   #4
bct10985
http://foreinnovations.blogspot.com/...ensor.html?m=1
Old 01-20-2020, 08:52 AM   #5
Juiced1
Drives: 2012 2SS CAMARO 45th
In situations like this we either make the sensor a dead end on the feed...So Y it off like jasycz28 mentioned. You can convert to a ethanol only tune but if you're doing that you're going to want to barrel feed it. There is a significant variance between E85 pumps some times, especially with winter blends. If you can't barrel feed it you'll need to monitor it closely
Old 01-20-2020, 08:53 AM   #6
bct10985
https://www.realstreetperformance.co...ter-black.html
Old 01-20-2020, 11:36 AM   #7
eLeSthree
Thanks Brian. This will work.
The dead end Y could work too, but might not get fresh fuel samples all the time.
1158whp 1017wtq.
630whp 658wtq
Old 01-21-2020, 11:18 AM   #8
Bildo
Bildo's Avatar
Drives: 2012 2SS/RS LS3
Dang works just fine on my return but I put it at the bottom of a loop tends to always be fuel present.
2012 2SS M6, ERL Superdeck 6 427, PRC 255 Heads, Procharger F1A w/ 3.85 pulley, 1300hp intercooler, Squash Dual 450lph, E85, ID1700, RXT Clutch, DSS 1pc driveshaft, GForce axles, Eaton Detroit Trutrac, a bunch of other crap I don't feel like typing.
Bildo is offline   Reply With Quote
Old 01-21-2020, 11:53 AM   #9
eLeSthree
I rewired my relays triggers so that 2 pumps run full time. The 3rd is boost triggered. Return stays full and FF sensor is happy.
1158whp 1017wtq.
630whp 658wtq
Old 01-21-2020, 12:02 PM   #10
blake-b
blake-b's Avatar
Drives: 2009 ZR1
I had no issues with mine in the return line as well.
