11-18-2019, 08:31 AM | #15 |
Drives: 2013 SS Join Date: May 2013
For the weight that's moving, pretty sure this is a record for the 5th gen SBE LS3.
The SBE LS3 was rebroken by Billy Telesco with a 7.78 @175mph a week after this pass.
11-18-2019, 10:29 AM | #16 |
Trouble_SM
Drives: 17' Summit White ZL1 Join Date: Jan 2015
I have to be honest. A 7.78 in the 1/4 on a stock bottom end ls3 is very hard to believe without seeing more details on the setup. If true, that is fast and I congratulate him.
11-18-2019, 10:46 AM | #17 |
Drives: 12 camaro ss, 72 chevelle, 91camaro Join Date: Dec 2013
No doubt! I find that very difficult to believe as well.
11-18-2019, 11:11 AM | #18 | |
Same car went and did Drag week also, all over YellowBullet, Boosted LSX and Turbo Bullet and has been confirmed by many and track officials. Race weight at 3200lbs.
Been following that build since he started.
11-18-2019, 11:43 AM | #19 | ||
Very impressive if legit! At that weight thatd be like 1700fwhp. Wow
11-18-2019, 11:46 AM | #20 |
I know our customer and friends 6.0 SBE Coupe only made 1287whp when they went 7s in theirs. Yet lighter tho. 3060lbs.
11-18-2019, 11:53 AM | #21 |
A lot of power for sure. My 8.38 pass is on a stock 6.0 long block @ 3420lb raceweight. So I know it's possible for sure. Just that ls3 block cant seem to hold the power the 5.3/6.0 blocks do
11-18-2019, 11:55 AM | #22 |
Trouble_SM
Impressive, but not a Camaro, so it does'nt count for what this record is for. It is a Camaro specific record on a Camaro forum.
11-18-2019, 11:58 AM | #23 |
Filled, they hold pretty good amount.
11-18-2019, 12:01 PM | #24 |
Yes I'm aware, that's what I mentioned on my 1st post. Your car holds the 5th gen SBE boosted record.
11-18-2019, 01:10 PM | #25 |
Drives: Caprice Join Date: Nov 2016
In all fairness, the OP is "Boosted LS3 sbe record broken". There was no mention of it needing to be in a Camaro, or a maroon Camaro, or whatever year and options or anything else. No matter what, your car is moving and that's something to be proud of!
11-26-2019, 03:48 PM | #26 |
Trouble_SM
Shooting for 8.99 or better for the final drag event of the year!
11-26-2019, 06:04 PM | #27 |
Drives: 2010 2SS LS3, 2013 duramax Join Date: Nov 2012
I went a 9.6@147 couple weeks ago with a 1.5 60’. Played with the low end timing and got it to do a 1.4 60’ but air filter came loose and got sucked into the blower damaging the impeller that run cutting my day short. Sucks that could of been a low 9 pass. Was hitting limiter on 1st-2nd shift also. Getting blower rebuilt and trying again in spring i guess.
12-16-2019, 01:53 AM | #28 |
LSx FTW!!!
Drives: 2010 Camaro 2SS RS Join Date: Jan 2017
What kind of power did you lay down on the dyno?
2010 2SS RS A6 781rwhp on E85
Stage 2 ProCharger D1X Circle D 3400 Triple Disc Kooks Jet Hot Headers Kooks Full 3in exhaust Trick Flow GenX 255's Polished PAC .660's & Ti-retainers TSP VVT 3.2 cam kit w/DoD Delete Smith Bro's Trunnion kit AEM X-Series OBDII Widebands FIC ID1300x Injectors GM ZL1 High Output Fuel Pump DSX Tuning Flex Sensor DSX Auxiliary Fuel System Tim King Stage 4 Max Effort CTSV 6L90 DSS 1 piece aluminum driveshaft JRE 6L80E / 6L90E Dipstick NGK Iridium IX spark plugs #7 heat range Mighty Mouse Camaro 5 Wild w/-12an and Billet Black HP Tuners VCM Suite |
Thread Tools | |
